Help finding a transciever
I am building a project that requires data transmission of up to 5 miles. I am thinking of an Xbee even though I have never before used one. Does anyone know the range of one?
Any thoughts?
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
Any thoughts?
I don't know of anything that can go further than that, but I haven't really looked for anything.
Edit: found xbee hardware (link above)
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Post Edited (Bobb Fwed) : 7/30/2009 8:53:05 PM GMT
Post Edited (sylvie369) : 7/31/2009 10:51:09 AM GMT
I am on limited budget and the total product cannot have more then $80 of stuff on it.
XBees are great but I seriously doubt you can *really* achieve 6 miles with them so easily. There's a good report on actual hand-on ranges on the SparkFun website. Also, antennae and operating environments are very critical in achieving anything like stated 'up to' ranges, especially 6 miles! I've used XStream, they work well, but I never got much more than a couple kilometers with a stubby antenna.
Cheers,
Alex
I use the AEROCOMM AC4490-1000M 900MHZ Transceivers, To get that range it's all in the antennas. you will need to get them up high and use as large a "GAIN" as possible. and yhey may need to be directional "YAGI" antennas I think?
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=AC4490-1000M-ND
The AC4490's are easy to use, ( once you figure them out of course), they run at 3.3v.
your "5 miles" will need to be LINE OF SIGHT, not easy to achieve in a city or built up area!
regards
Dave M
Earl
We get over 1000 foot range in downtown Santa Monica and they advertise 17 miles range with the proper antenna. As
someone else mentioned "its all in the antenna"
Russ
Great Antennae AND excellent reflective planes AND slow data rate AND ideal environment AND lots of votive lamps, but I like the XStream transceivers. Simple, reliable, to the point. Somewhat big, though. We used them in mobiles (moving vehicles on highways at highway speed) and this is where you can really assess the 'up to range' specs of a datasheet! we are actually proud of having achieved a few kilometers. Antennae were covert (definitely not visible yagis or whips) and relatively high data rate. 5v not an issue as we used PICs and automotive battery source.
@Ole Man Earl:
About XBees: XBees are fine products for embedded comms. But '10 miles easy using a yagi and duckie on uav': really? some yagi and some line of sight! What kind of link is it? You definitely hit some sort of RF jackpot. Your environment must be pure RF bliss... What's the specs of the yagi and how high is it located above ground, the environment (is it urbanized?), the data rate, the overall design, the travel speed of your uav? We'd love to get half of that distance 'easy' with the XBees even if they're NOT moving. We have about 40 in stock, not fessing up to the 'up to' specs. Sorry if I sound a little skeptical but your experience with XBees is much more enthusiastic than ours. Why not share the goods...
Cheers,
Alex
A Mesh network! As long as one bikes is in range you can set them to retransmit until it either hits maximum hop limit or the target.
Of course if you're interested in that, you should definitely read the legal info on it... I have no idea whether you're allowed to transmit data on those channels, or if it's for voice only, and IIRC FRS radios are required to have permanent antennas, so if you modify the antenna, stay off the FRS channels (plus I believe FRS is limited to 0.5W, unlike GMRS, so the range won't be very good).
DogP
Do you really know about RF ??
I send data signals >15 miles everyday on 2.4 ghz with 9dbi omni ants at both ends. Yes it is clear line of sight rural area flat ground. I used to use 20mw at over 5 miles with 15 dbi grid ants. I DO know what I am talking about on this subject as I have OVER 40 years experience.
XBee or 802.11 on 2.4 ghz doesn't matter. RF is RF is RF. Do some math with Radmobile and see for yourself. I have this knowledge from owning a wireless ISP for over 8 years.
So don't chid me about RF. On a bet I can show you two 60mw XBee radios passing data with one being a 7 dbi rubber duckie on a UAV at 600 feet and the other end being a 24 dbi grid antenna on the ground with clear line of sight at 10 miles.
Old Man Earl
Weren't you telling me that you lived out in the desert near Phoenix ? We were talking in the hotel
the morning after the Propeller Conference.
Russ
Oh dear, oh dear, oh dear. Calm down. I didn't meant to ruffle your feathers. Assumptions were using XBee to XBee, as provided through DigiKey or SparkFun, as per microcontrolled 'as cheap as possible' requirements. In that type of configuration, you simply don't achieve very long range. My comments are in line with all the other posters on this, it seems. You did mention using a yagi, so I simply asked you about the setup. No offence intended, really. Now I hope this gets you off you high horse (so to speak) and thank you very much for answering my rather esssentially technical questions. BTW I see no major feat achieving 600 feet using 60mW XBees, clear LOS rural. And yes dear, I do have some knowledge of RF (~25yrs). But this isn't a contest for the most grey hair, or is it?
Cheers,
Alex
@Russ No, I line in desert 75 mi SE of ABQ,NM
my whole house running on it soon. We just felt that the X-Stream modules were better suited
for our application.
We make PoS terminals for school cafeterias and needed to be able to say sell hot dogs out on
the football field. The terminal can then transmit the data back to our transaction server on the
schools network and deduct the cost from the students account. Parents fill the account over
the internet and then have a record of exactly what there kids are eating.
Russ
That might not be possible. But you could get close. I've been working on a wireless mesh project for the last two years. It is not simple and I have a whole shelf in the shed filled with failed RF experiments and projects. That inludes hacked audio walkie talkies, hacked radio controlled toys, hacked long range (1 watt) video transmitters and multiple experiments with antennas from 1Mhz to 2.4Ghz. Then there are experiments which did work but which turned out to be illegal.
Right now, I'm working with these modules www.yishi.net.cn/rf/ProductShow.asp?ID=98
I've got several kilometres through trees and not a direct line of sight, so there is potential to boost that with yagis with only a few elements.
Cost was about $40 each - so there goes the budget. But they do replace a wired connection very easily. I went for the lowest baud rate because lower rates = longer range. Also, these modules have a -123db receiver sensitivity which is quite an amazing number.
There are quite a number of modules around - I went for the Yishi ones because they can handle placket sizes of up to 256 bytes wheras most modules are only 32 bytes. Xmodem can then be used to transfer files/pictures etc. I have xmodem working on CP/M boards and very soon will have it working on Cluso/Heater's zicog prop emulation. So then it would be a prop+RF module project. Still might be difficult to get <$150 though.
Post Edited (Dr_Acula (James Moxham)) : 8/3/2009 12:51:54 AM GMT
· -- Carl, nn5i@arrl.net
