What is the best way to provide +/- 12VDC to opamps?
I'm working on several sensors circuits (pH, ORP, Conducitivity) and all the low-input bias FET opamps I've seen so far al require a minimum of +/- 7VDC supply.
What is the best way to provide +/- 9 to 12 VDC?
I've played with ICL7660 but they max out at 10VDC, don't drive much and the voltage drops off fast under load...even 20ma.
Thanks.
Scott
Thanks.
Scott
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
An example that I keep around in my own shop is the dual LMC6062 from National. It has a 16 femtoAmp typical input bias current and other characteristics that make it suitable for a pH probe interface. All the op-amps in the National LMC series are CMOS devices, and have trade-offs of accuracy, bandwidth, power consumption and all the other characteristics that you have to sort through when choosing an op-amp, but CMOS input generically is often the best choice for high impedance pH type interface. At Linear Tech, the same applies for op-amps with the LTC prefix. At TI it is TLC.
There are times when a +/- 12 or 15 volt supply is a good idea, but that has to do more with the common mode noise one might run into in an industrial environment, and in those environments it is often necessary to take one big additional step to provide a galvanically isolated interface to the pH probe. That means an isolated power supply and an isolation barrier for the data, either digital or analog.
Tracy Allen
www.emesystems.com
Scott
I'm considering running a differencial design with an opamp on both ends of the BNC then feed those to a comparitor opamp. I've also tried adding a 'guard' circuit around pins 2/3 and tie that to the substrate ground, but the voltage still drifts.
Back to the drawing board...
SCott
You have to establish whether the drift is within your circuit, or coming from outside. Try a steady known voltage source at the input, say, a lithium coin cell with a voltage divider made with MOhm range resistors.
Is the op-amp hooked up as a voltage follower? If so, the guard voltage should come from the output and surround the non-inverting input pin. But that is not the problem if the input pin is lifted away from the circuit board and connects directly to the BNC center pin.
Tracy Allen
www.emesystems.com
For now, I'm using a DC to DC converter (NMH0509S) that converts 5vdc to +/- 9VDC (111ma) to power my opamps because ... well ... I already have them...
If I disconnect the probe, the output voltage drops to V-.· If I connect the probe and leave everything alone the voltage will stablize. However, if I bring my hands within about 2 inches of the board the voltage drifts again.· Very, very sensitive circuit.
I'll try your suggestion of replacing the probe with a fixed voltage like 1.5 or 3VDC battery and see if that makes any difference.
I'm playing with the circuit from OPA129 datasheet 'FIGURE 5. High Impedance (1015Ω[noparse];)[/noparse] Amplifier.'· See attachment.
Thanks.
PS Since I have four of these, I'll try a differencial circuit to see if that makes it less sensitive.
Scott
How is the wiring, especially to the high impedance inputs? It should be short and direct. Shielding (a metal box) might help too. The same thing with the OPA129 circuit.
Tracy Allen
www.emesystems.com
I finally figured it out. For the 500 ohm resistor, I mistakenly put a 51 (green brown black) instead of green/brown/brown. So, instead of a gain of about 20x my gain was 200x. No wonder there was so much 'drift'.
After replacing the resistor, I did a quick and dirty check with ph solutions (non standard) of ph8 and pH 11 and received voltages of ph8=-2.0; ph11=-5.1; which is consistent. It also looks like I need to adjust and invert the output because the voltage is going negative.
Thanks again guys. Looks like I have a working circuit I can develop now.
Scott
Don't worry. Be happy
Oh, and you could of course use 7812 and 7912 to get +/- 12V.
