Video - UAV Boat Project Sinks - Propeller and GPS Work Underwater
SuperCricket
So here is a video of my summer long UAV project.· I decided to do it in a boat instead of a plane.· A few months later and nearly $500 in electronics in the thing and I was ready for the first test.
You can see the boat completely dissapeared underwater.· However one cog was strictly for motor control and its directives to stop the motors were if the boat reached its destination waypoint, or the GPS lost signal.· The ole Parallax GPS worked under water long enough for it to keep firing the motors until the boat popped back up from the surface.
The uController SD card kept logging the whole time under water too.· Not sure what all is fried yet.
http://www.youtube.com/watch?v=VdM_h-cGjBo
UAV IS HARD.· Enjoy!
That sucks your boat sunk, maybe a larger hull would stabilize a bit better... I'm no boater, but even those small lake waves on such a small boat would want to flip it even without the "gps mast".
Maybe you could put a stabilizer on the bottom with a weight about a foot under water or so to counteract the sway from the mast.
Oh well, hindsight is 20-20.
You are just a few large servos away from automating your real boat, if you were so inclined. [noparse]:)[/noparse]
EDIT: Thinking about it, since you have to have that battery weight anyway, why not move it down below the boat in a water tight enclosure? A little PVC, some silicon, and you could power your boat from a ballast under the water. You'd get double returns on your "investment", since you'd be lowering your center of gravity by getting the battery out of the hull, and by putting on an underwater counterweight. Performance would take a hit, but I don't think that is the main idea here. Like I said, I'm not a boat guy, but I know how summer projects are... desperation ensues.
Post Edited (Tired2) : 7/30/2009 1:55:06 AM GMT
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
good attempt - and thanks for sharing even in the mistakes!
Here's the one rule your design seems to have left out:
Weight's always end up below floats.
Hope you'll be able to salvage the best!
[noparse][[/noparse]EDIT: Nice mathematics work, BTW.]
Cheers,
-Howard
(Working on a submersible - see over in the robotics area.)
Post Edited (CounterRotatingProps) : 7/30/2009 1:20:01 AM GMT
Keep at it and good luck.
Nice yacht, by the way.
Phil
2 cents worth: Rather than redesign this boat, is it possible to tow the GPS in another boat (raft, float, tube,jet ski... ).
If the boat was stable without the heavy mast this just might work.
Roger
My idea has been to use my 8' PortaBoat and 3.5 HP outboard. That thing so stable. I've crashed into things in the middle of the night several times with no problem, on account of its somewhat flexible materials. With me in it it planes an 10 knots, autonomously it could holds a lot of gas an go a long distance.
Very neat project! You need a keel or outriggers with that weighted pendulum up top though.
If you wanted to build a UAV (aerial vehicle) originally, you should know about weight and balance. Boats use w&b too. Your mast should be mounted at center of balance. Use a counter-weight on a keel beneath the boat. That will serve the purposes of stabilizing the boat in both roll and yaw, as well as counteracting the effect of the mast.
Good luck!
Ned
"They may have computers, and other weapons of mass destruction." - Janet Reno
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Just my 10 bits worth.
Doug
John
'Necessity is the mother of invention'
'Those who can, do.Those who can’t, teach.'
'Convince a man against his will, he's of the same opinion still.'
Very cool project with big possibilities! Keep at it,
Michael
post edit:
Noticed you didnt have EMI cans over the motors, they might allow you to put the GPS right on the deck. U may be able to solve the problem of EMI with a sheet metal (steel pref) cover for your deck. An alternative WITH using the mast idea, is to implement an accelerometer or heli gyro about half way up the mast to counter the roll rate of the boat when turning with a slightly larger rudder/servo. For the compass... a two axis swing tray would keep the compass pretty level, but then youd need to dampen the oscillating motions enough. Easiest way to stabilize is with your suggestion of outriggers, say like 12" from each side of the boat.
ALSO, i have a 48" R/C boat initially made for nitro but it has no guts/paint. If your interested in a bigger boat.. PM/email me.
i32.tinypic.com/2chqgq9.jpg
i32.tinypic.com/4ta5xx.jpg
i32.tinypic.com/28moe95.jpg
Quicker answers in the #propeller chat channel on freenode.net. Don't know squat about IRC? Download Pigin! So easy a caveman could do it...
http://folding.stanford.edu/ - Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
Post Edited (RinksCustoms) : 8/5/2009 4:13:42 PM GMT
For your design, perhaps you'd consider catermeran hulls (i.e. three hulls) instead of just some floats. You might do well to just use smaller scale boat hulls to minimize your drag. Did you have the opportunity to try your vehicle in a pool or smaller test setting? Perhaps alternatively you could ferry it on a RC car for testing of your subsystems?
I have my own stability problems I'm trying to solve with some more control surfaces. I'm trying to retrieve some objects from the bottom of a pool. I'm using the BS2 to control a PS2 joystick that interfaces with a custom 3-motor H-bridge.
Here Inky is struggling against the tether to pick up a ring on the bottom.
[noparse][[/noparse]youtube]
This time it does better after it's been straightened and the retrieval hook is tightened and lowered.
[noparse][[/noparse]youtube] [noparse][[/noparse]/youtube]
My stability problem is largely about the center of gravity since my thruster clearly is misaligned. However the weight of the ring shifts it across the CG in the opposite direction. So my proposed solution is a 2nd vertical thruster. Unfortunately I'm running out of control lines. With PWM I'll need more. So I'm looking to a combination of perhaps 2 BS2s that I have on-hand with a Propeller chip.
So going forward, I'm going to redesign the frame a bit to hold two vertical engines and install an accelerometer (from Smart Sensors) , an onboard camera (potted in epoxy), LEDs (for both lighting and strobe), and a compass (from Smart Sensors) for semiautonomy. The objective is that the robot will detect the ring and alert the operator with a strobing LED. The robot will also have finer attitude control by using control guidance to PWM the motors to maintain a heading. I will also attempt to do some recon & retrievals autonomously or at least have some of the end-game autonomous with myself setting up the rendevous with the target.
Post Edited (ceruleanplains) : 8/11/2009 4:09:03 AM GMT
