accelerometer & gps recommendations — Parallax Forums
Peter JakackiPeter Jakacki Posts: 10,193
edited 2009-08-09 11:39 in Accessories
I'm just looking at some options for accelerometers and gps but just like many shoe shops there are just so many to choose from. This is mainly for general use so I guess there are always trade-offs with which-ever choice we make. Mouser lists quite an array, here are a couple of devices that I am considering:
Accelerometer: MMA7660FC (I2C)
GPS: MN5010HS, SKYTRAQ VENUS634FLPx
Anyone had any experience with these kind of devices and perhaps if you had a few pearls of wisdom to share?
*Peter*
  • LeonLeon Posts: 7,620
    edited 2009-07-29 11:53
    I've used the Freescale MMA7260Q accelerometer (analogue outputs). It's very easy to use, but needs to be placed close to the ADC inputs otherwise it picks up a lot of noise.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • TimmooreTimmoore Posts: 1,031
    edited 2009-07-29 17:01
    I have also used the mma7260 without problem, I have also used the LIS3LV02DQ, its nice when you dont have a ADC - its I2C, it also has selectable g ranges. Also the LIS302DL is the same if you dont need more than 8bit resolution.
    In terms of gps i have used the SANAV FV-M8 and it worked well.
  • RaymanRayman Posts: 16,036
    edited 2009-07-29 18:36
    mma7260 works well in my PSM and is very low cost compared to alternatives...
    edited 2009-07-29 20:23
    This thread is being moved from the Propeller Forum to the Sensors Forum.
    Parallax Engineering
  • JavalinJavalin Posts: 892
    edited 2009-08-09 08:16
    the ublox range of GPS's are the best for acuracy etc, that i've found.
    www.ublox.com
    Any acceleratometer should do the job - try the sparkfun boards if you want a break out - www.sparkfun.com
    James
    I like the u-blox GPS units as well. They are very easy to use - I've even put one on a home-made PCB. The AMY-5M is the smallest unit on the market at 8 mm x 6.5 mm!
    Leon
