Fast, Faster, Fastest Code: Integer division
Hi All,
A code or algorithm must be correct. When it is, after some debugging, we can make a compromise between its code size and speed. There is always a compromise, but sometimes it does not matter. When either speed or size is a factor, there are methods to boost performance. There might be a 'Small, Smaller, Smallest' flavor of coding for a given language/hardware combination, but in this kind of thread I am looking for very fast codes. As, we have these days the luxury of more and more code space, but of time, we don't.
Even when divide hardware is available, it is quite common to find that divide instructions take more than twice as long as multiply instructions. When division and multiplication are done by software, dividing is usually slower than multiplying, too. However, we can improve speed by noticing, that many integer division operations found in real programs involves division by a constant. When we know the numbers we are dividing by in advance, we can substitute the divisions with multiplications and with some bit shifts.
When the constant to divide by is a power of two, we can shift the number to be divided to the right by the exponent, and that will complete division
(some_integer/constant(=2^N)) = some_integer >> N
This bit shift is only one operation, four ticks with the Propeller. Can we do something similar when the constant is not a power of two? Yes. The·basic idea is to approximate the ratio (1/constant) by another rational number (numerator/denominator) with a power of two as the denominator. Instead of dividing, we can then multiply by the numerator, and shift by the exponent in the denominator. In case of 10, for example, the (1/10) ratio can be substituted with· (205/2048). The (some_integer/10) division can be calculated with a multiplication (some_integer*205), then the product is shifted right 11 bits to get the result of the division by 10. In short notation
(some_integer/10) = (some_integer*205) >> 11
To divide with 100, the rational number (41/4096) works nicely
(some_integer/100) = (some_integer*41) >> 12
For 1000 we can realize that it is 8*125. So, if we first shift 'some_integer' to the right by 3, we only need to divide the result by 125. When (1/125) is approximated as (67109/2^23)=(67109/8388608), then the simple formula
(some_integer/1000) = ((some_integer >> 3)*67109) >> 23
works for integers up to almost 400_000 with high accuracy.
To figure out the (numerator/denominator(=2^N)) approximation for an arbitrary (1/constant) factor, first we have to fix the required relative accuracy of the division. When 1% relative accuracy is adequate for the application
- we multiply the constant with 100.
- Then we find the smallest power of two, that is bigger than the product.·For (1/2009), 262144 is that, so the denominator is 2^18.
- Then, we·obtain the numerator by dividing 2^18 by the constant 2009. That gives 130.48. After rounding to the nearest integer, we have··the·rational approximation·of (1/2009) as (130/2^18).·
It goes, in short
(some_integer/2009) = (some_integer*130) >> 18
Or, doing an evident simplification, it is
(some_integer/2009) = (some_integer*65) >> 17
For a ten times better relative accuracy of 0.1%, the formula is
(some_integer/2009) = (some_integer*1044) >> 21
After simplification, it is
(some_integer/2009) = (some_integer*261) >> 19
The previous simplications decrease the numerator and are useful, since the (some_integer*numerator) product has to be smaller than 2^32, to avoid overflow with the 32-bit multiplication.· 2009 is an odd number. For even constants we can shift out the power of two factor from their primes, before the division. So, to divide with 2010 at 0.1% accuracy, one can use
(some_integer/2010) = ((some_integer >> 1)*1043) >> 20
The initial right shift for an even constant increases the range of validity of the algorithm at the cost of an additional operation.I wonder wether all these beat unrolled division?
We have just substituted a division by a multiplication, but elimination of multiply instructions is itself desirable. For example, according to the Pentium instruction timings, the base time for a 32-bit integer add or subtract on that processor (discounting operand fetch and other overhead) is 1 clock cycle, and both can sometimes be paired with other instructions for concurrent execution. In contrast, a 32-bit multiply takes 10 cycles and a divide takes 41 cycles, and neither can be paired. Clearly, these instructions should be avoided wherever possible.
In case of multiplication with a constant we may ask, that
- Can we can do faster integer multiplication with a constant with only· bit shifts and additions? (The answer is probably: yes. And remember, numerators were contants...)
- Can the (1/constant) ratio be calculated even faster with only bit shifts and additions?
I think the answer for the 2nd. question answers the 3rd, too.··
Trespassing the Regime of Fixed-point math (or not?)...
Fixed-point representations, in which the point is implicitly placed between any bits of the binary representation of a number, have been used since the dawn of the computer age. In the PC world fixed-point arithmetic has become a lost art among programmers. Since the introduction of the 486 CPU, a fast floating-point processor is an integrated part of the CPU, and therefore there is rarely a need to work with fixed-point numbers anymore. In embedded applications fixed-point arithmetic has still its places, and there is no excuse to use inefficient or imprecise methods with those limited resources. Moving away from integer arithmetic to fixed-point numbers is one step forward to close the gap between the speed of integer math and the ease of use of floating point arithmetic.
When fixed-point numbers are used, all arithmetic operations use integer arithmetic, and this leads to a considerable performance advantage. This comes from that a binary fixed point number is, for all purposes, an integer number. You simply cannot tell the difference by looking at it, and neither can the machine level math functions. For those math functions, the numbers are just integers. That's the beauty of it: you use the same machine level functions you would for integer math, plus a little bit of housekeeping for the point at multiplications and divisions. (John Von Neumann said once, that a competent programmer never needs floating point hardware because he should always be able to keep the point in his head. Well, his words are just remembered by others, he never wrote them down...)
With fixed-point arithmetic we can choose the precision of the numbers, because we can distribute bit usage between fractional and integer parts of a fixed number in any way we like. So, we can adapt a very fast code to very different accuracy demands.
In fixed-point, the simple integer division is the worst basic operation, because it loses precision the most. To somewhat remedy that, we can use multiplication by the reciprocal of that number (1/number) instead. To whet your appetite for fast and effective fixed point ASM code, I show a way to divide by 10 with faster, more efficiently and·more accurately, than·with the discussed acceleration method.
quotient = ((some_fixpoint >> 1) + some_fixpoint) >> 1
quotient = ((quotient >> 4) + quotient)
quotient = ((quotient >> 8) + quotient)
quotient = ((quotient >> 16) + quotient) >> 3
where 'some_fixpoint' can be any unsigned 32-bit number.
To make it even faster
quotient = ((quotient >> 8) + quotient) >> 3
but 'some_fixpoint' here should be less (in integer format) than 534_890.
If you know other tricks or methods to speed up integer or fixed-point division or multiplication, let us know, too. SPIN or PASM test codes to check, improve or maybe to bust these ideas, are welcome.
Cheers,
istvan
Post Edited (cessnapilot) : 7/29/2009 7:10:30 PM GMT
It goes, in short
Cheers,
istvan
Good summary of interesting methods for optimization.
Why don't you write up some of these routines in assembly code and publish them as a library in the OBX.
You could label each with accuracy and range of use values.
Then the coders could pick-and-choose to meet their needs.
Jim
Well, I plan something similar. A speed optimized, but small sized Q4.3, Q8.7 and Q16.15 fixed-point library toolkit will cover that. As for the thread, there will be other 'Fast, Faster, Fastest Codes'. Next,·quick ATAN2 and SIN/COS will be presented with actual fixed-point codes. I am preparing a user frienly SPIN interface for··a living testbench beside the post. This interface is under construction, but works now (check attachment). The first post became too large, before I even mentioned reciprocals, so I chopped the material.
The attached 'Plug and Play' PST application tests and compares the 16-bit multiply/divide routines from the Propeller manual and shows, thanks to the·smart CMPSUB, that for the Propeller the software multiply and divide run about the same speed. Plug your PASM codes instead of·them, and you are on your way...
Istvan
(PS.: 6DOF·IMU works! Testing and calibration·follows...)
Post Edited (cessnapilot) : 7/29/2009 7:11:54 PM GMT
I looked at your sample code.
You're off to a good start. It looks like this could easily be organized into a very useful library.
Keep us posted on the progress.
Jim
