Error message when opening an SXB file
I recently upgraded to SXKey 3.3.0. Now when I try to open an SXB file, I get an error message titled "Command Line Parse Errors" with a message that says "C:\Documents: Invalid commandline parameter #1. If parameter #1 is a filename, it must be the last parameter on the commandline." If I click ok to this message, I get a blank SXB page even though I tried to open an existing file. I can go to the File/Open menu and open an SXB file and things work ok after that. Strange thing is that the "open a file" icon at the top of the page is inoperative. I've tried nearly all my SXB files and get the same results. They opened fine with the previous version of SXKey. Any ideas on what's wrong?
Yeah, it looks like the File Open icon doesn't work properly.
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
