Accelerometer Weight Scale
                    Hi I was reading how the accelerometer uses gas and thermometers to determine the x y z locations, from what I can tell, by using the gas technique, if u had the accelerometer flat and level on a table, if you added weight to it, it wouldn't know the difference correct? I'm wondering if there is some way to program it to detect weight to be used as a scale.
If this could be done, I think it would be awsome to beable to weigh things with devices that use accelerometers such as mobile phones
Thank you!
- mike
Thank you!
- mike
Parallax Engineering
Here's the formula: T = 2π sqrt(m / k), where T = period (seconds), m = mass (kg), k = spring constant (N/m)
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Or, as this is electronics related, how about electrical tape, then you can even have your choice of colors to match the phone.
John R.
Click here to see my Nomad Build Log
http://www.tapebrothers.com/Duct-Tape-s/1.htm?Click=6446&crtag=Google&gclid=CO3z_8nc-JsCFQtN5QodqHub-A
It's a new day!
