BS2 current draw in sleep while powered on Vin.
I have a project where I am looking to create a low voltage shutdown for my batteries.· I am using the stamp to create a high/medium/low charge indicator and a timed load shutdown since the regulator is not a switcher.· I have a possible discrete circuit for total load shutdown if the batteries get too close to total discharge·but I was looking at the Stamp and noticed the module can take unregulated input too (I missed that at first).· I was wondering though if the low power sleep current draw applies if the stamps on-board regulator is running?· I was searching around but I wasn't having much luck finding that directly answered but several of the kits seemed to suggest that using the regulator negated the sleep savings which made sense.· It would save a lot of design and wiring if the stamp can draw that little on unregulated supply during sleep and I just use it to cut the regulated load off if the batteries drop below the trip point.
You'll have to go through the schematic looking at the various current drains in the Stamp module to come up with an exact current drain, but the quoted values for a BS2 are 3mA active and 50uA when sleeping or napping. This doesn't include any loads.
www.emesys.com/BS2power.htm
However, nothing will go as low as a total cutoff switch, zero power.
Tracy Allen
www.emesystems.com
The only issue it would raise is the short output flicker that happens when the stamp wakes. I could probably solve that with a R/C circuit to hold the P-Type MOSFET high and keep it from pulsing the load on and off too while the stamp drops the pin as it wakes.
Cool. I'll have to wrestle this around a bit in my head.
