SpinStudio ADC module
I have a new product that should help to fill an obvious hole in the SpinStudio line-up. Analog measurement.
The SpinStudio ADC adapter incorporates a MCP3208 ADC into a easy to use, plug-in module for the SpinStudio system. The MCP3208 is a very capable ADC with 8 channels and 12 bit resolution. The maximum sample rate (when using 5V max sample voltage) is 100K samples/second. A selectable jumper allows use of 3.3V or 5V as the maximum sample voltage, allowing measurements from either 0 - 5V or 0 - 3.3V in 4096 increments. An SPI interface is used for data transfer.
There are several well written objects in the OBEX for the MCP3208 ADC. This is a recent thread involving a new object - http://forums.parallax.com/showthread.php?p=825900
ucontroller.com/index_pro1.html
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Brian
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
Brandon C.
No purchase necessary. See back panel for more details.
Tired of the same old robot brains? not enough processing power? Get the Propeller Robot Module now!!
