What should I get?
Okay, for my birthday tomorrow, I am getting money.· There is a 15% discount on an order placed when it is your birthday, so...
I don't want to spend any more than $70.
One thing is, I know I don't want a BASIC Stamp module.
Thanks for your suggestions.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
··Thanks for any·
Sam
Whats wrong with the BS2?
________________$WMc%_________
The Truth is out there············································ BoogerWoods, FL. USA
Normally: $79.99
With Discount: $67.99
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Parallax USB Oscilloscope - out of price range but extremely useful to have a scope.
$WMc%,
I really like the Basic stamp, but since I already have a BS2 HWB and have mastered every aspect of it, I am leaning more towards the prop....
I was looking at that μOLED-128-G1... That would be awesome...
I don't want to spend too much, because I want to save up for the expo.
I'm thinking about getting the HYDRA book and RCA and PS/2 breadboard adapters--approximately $51, as well as a few parts from Digikey. Is the HYDRA book + Propeller chip worth it?
Thanks.
The BS2 code is much more simple, so I utilize it to understand a new sensor or device quickly. It provideds a small learning curve and lets me focus on the theory and the input or output of the the new device or sensor.
I use the Prop in the final projects. They are dirt cheap and way more powerfull with multiple cogs.
If you dont already have a Prop, I would buy one. If you are aware of the idea of "Modules' in a typical programing language, you will love the Prop. People have writen modules that can be downloaded in the Object Exchange area of the parallax site and you can simply call them in your projects. I have 3 props and find my Propeller Education 40-pin DIP kit gets the most use and even it is easy to connect to a TV via 4 pins of the chip connected to 4 resistors and a RCA connector.
I guess it goes without saying, my vote is Get a prop kit!
There's a common saying: "You can get 80% of the results with 20% of the effort."
I'm guessing his 70% only takes 10 or 15% of the effort. I have lots of 69% completed projects myself.
Thanks Leon. I didn't know it had a name.
One of my chemical engineering teachers said it in a class lecture.
http://en.wikipedia.org/wiki/Pareto_principle
Possibly, but if you want to do larger projects then it does get expensive, like $2000 a board expensive: http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,400,795&Prod=XUPV5
Of course, the OP is now academic so it's much cheaper ($750), and it is a top of the line board.
