Optrex graphic display DMF-50840-NF-FW
Hi All,
Finally got my new off grid living situation under control and have a place to work again! I want to use an Optrex graphics·LCD display, part # DMF-50840-NF-FW. I have found the data sheet, but can't seem to find any information on specific commands. I haven't really worked with graphic displays. Is there any object in the exchange that might work? It's a standard 4 bit parallel interface. I'm going to wire it up and see if I can get it to do anything, but I thought I'd check here and with any luck avoid many hours of messing around.
Thanks!
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Thanks!
Jonathan
If you do decide to try it, remember that getting the screen to show contrast should be your first step. I think that controller has the negative voltage generator built in, so you will need to get the caps set up right I think.
Jonathan
Follow the Avnet link and you won't have to send your email address for the "specification" ... see .pdf on Avnet site.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
I had seen that page and downloaded the Specs PDF. However, I noticed a link for "other app. notes" and there was one that had commands!
TYVM! A second look never hurts! Now all I need to do is get the CCFL backilight going.
Jonathan
