Board of Education - Maximum Input Voltage?
Hi All,
For my application, I really need to be able to use a 12v battery to power my BoE. . .I've looked at the specs for the on board voltage regulator and I can't see why it would have a problem managing 13-14v from a battery. The max stress rating on the voltage regulator is 26v and clearly I'll never be anywhere near that. So why does the board indicate that it needs 6-9v? I actually have been running it on 12v for a while now before I even noticed the rating.
Any thoughts? Am I okay to continue operating on 13.8v?
-Jeff
-Jeff
Don't worry. Be happy
The 6-9V rating is based on near maximum current and the amount of heatsinking provided on the BOE (and typical ambient temperature).
I'm guessing that a resistor based voltage divider is essentially the same yes? What abour using a zener diode? All of the simple circuits I see are one of those two, aren't both going to dissipate voltage as heat and have the same issues?
I'm driving two ULN2803A transistor chips, a Ping)) sensor, a Sensiron Temp/Hum, an IR sensor, and reading a bunch of active high switches. . .seems like that might overwhelm the power regulator eventually. . .?
-Jeff
A voltage divider works very poorly for dropping voltage when there's any significant amount of current involved and even more poorly when the current can vary a lot as in your case.
A Zener diode could work, but is relatively inefficient, particularly when the current drawn is very variable.
Thanks! This is actually not an automotive application, but a lot of the same principles apply. My project enclosure has a fan, so I'll pick up a heat sink and position the regulator near the inflow. Thanks!
-Jeff
