slow RX/TX with (28180) RF 433MHz RX/TX Modules
Hello All
I'm trying out the RF chips from Parallax.
TX part#(27980)
RX part#(27981)
I've loaded the demo codes for the RX and TX units. I listed them below
The code seems to run very slow,And Hang up for a few Seconds. Is this the normal speed and behaver of the RX/TX units?
Will the RF units run faster with some better code?
I googled the RF units, But didn't find anything about the speed or transfer rate.
The Demo Code sets up 9600 baud-inverted.
I have the units talking to each other, Their just really slow.
Any help would be greatly App.
_________________$WMc%________
The Truth is out there············································ BoogerWoods, FL. USA
Post Edited ($WMc%) : 7/25/2009 5:24:13 AM GMT
TX part#(27980)
RX part#(27981)
The demo code you posted is slow because it packetizes the data and computes a checksum. That slows down the processing significantly. You may also have enough RF noise present that the RX and TX units are getting a high error rate and may be retransmitting the data repeatedly until it's received correctly.
Either get a faster Stamp or switch to a faster microcontroller like the Propeller or dispense with the error checking or simplify it and deal some other way with the errors.
The Baud rate is obvious. It was the time between packets that I was getting at. My fault for not being more descriptive.
I have moved the two units farther apart and I've shut down some other RF equipment and the packet time is improving.I have far less hang ups.
I think I need to ditch the crc and packet format and try a different approach to get the response I'm looking for.
I need some kind of error checking.
Any other Ideas would be greatly App.
__________________$WMc%___________
Post Edited ($WMc%) : 9/4/2009 3:01:40 AM GMT
I've built a 44" BushHog/Mower with a 17HP B&S. This is a 3 wheeler design just like the BOE bot. I have 2 600watt 24volt DC motors driving this Mower much like the two servos do on the BOE bot.
I have a BS2 on the mower along with a RX(27981) and a TX(27980) modules. The remote has a BS2 and a RX,TX modules as well.
Since this Mower is very powerful and potentially dangerous, I need to make sure the remote and Mower are in range and talking to each other.
--- If no signal from remote in 1000mSec,---STOP DC motor movement, ---If no sig. from remote 1000mSec after the first 1sec timeout,---Shutdown B&S engine.
I'm trying to make this as safe as possible.
This morning after coffee, I grab a coke. I set the can down just behind the Pro Dev.Board that I have the remote RX/TX modules on. I started receiving packets on the BOE at a much faster rate with few hangups.
Did I shield some RF interference or correct a SWR issue with the TX module?
just a note: I do have a lot of RF. WiFi,Bluetooth,cell phone,cordless phone,Satellite Internet,etc.
If I can get the error rate below 250mSec. This wold work fine for Me.
Any help or explanation with this RF modules would be great.
________Thanks in Advance___________$WMc%________
Who knows? The can might be acting as a reflector or director. Your neighbor might have turned off something.
Remember that motors, particularly big motors, make a lot of RF and electrical noise.
There's no way I can give you any kind of useful specific advice. Too much depends on the particular electrical environment and RF environment of your robot and the remote. At the short wavelengths and low power involved, all kinds of things come into effect.
My own personal preference is to use xBee modules or xBee-Pro modules. They handle their own packetizing and error detection and correction. They run at 2.4 GHz which is subject to interference from WiFi, Bluetooth, wireless phones, etc., but is very little affected by electrical noise.
I'm running a battery of test with the RF modules. Something I should have done before starting A Post.
Thanks for the Replys
________________$WMc%____________
Ha! (Referring to our PM exchange.) That is why I want good, solid remote control, as well! I want to cut my grass!
Unfortunately, I do not think Bluetooth will make the cut, pardon the pun, and am looking forward to Parallax's development of the WiFi module they semi-announced on the Prop board.
--Bill
You are what you write.
I'm thinking a couple of Beta testers (Bill C. and Walt Mc.) would help Parallax get this WiFi module going!
You are a veritable genuis! I am ready, willing, and most of all, WAITING! [noparse]:)[/noparse]
If done correctly, a Parallax WiFi module will be a tremendous hit.
--Bill
Dave
I got the RF modules working like clock work. I ditched the code examples for the 27980 and 27981, and wrote some stuff of My own along with some code from the Parallax Lib.
This is just a DEBUG setup, But its very useful when starting from scratch with the RX/TX modules.
I have a very advanced code written for this project. But I still have a few bugs. When I debug this program I will post it.
For now, here is the debug code for the RX/TX 433mHz modules.
Its not the greatest but it works.
I hope this helps You with the requests in Your E-Mail.
______________$WMc%______________
Ron H.
The documentation is in error. 19.2kbps is too high for these modules. The chipset is only rated for 10000bps. WE obviously need to correct that, however that limits the upper baud rate to 9600bps. As a note I think the example code pauses between packets. If you remove that pause it should be continuous. I’d have to look at the code in detail to see why the author put that in there. Take care.
Parallax Engineering
·Here is a better Code with more inputs
The communication is pretty fast.
See Attachment below
________________$WMc%___________________This works good for Me______
Post Edited ($WMc%) : 9/6/2009 4:55:13 AM GMT
