GBS301: Any luck?
There are a couple of old posts about people trying to use the GBS301 to program their BOE-Bot. Has anyone figured out a way to make it work?
Some have said it's not possible. Does anyone know why that is, aside from it using some sort of special signaling? (I'm curious what is special about it, basically.)
I am able to read data from the bot, but when I try to ID the stamp I get the message "No Basic Stamp detected" when the GBS301 is connected directly and "Basic Stamp 2 detected, but is not responding" when I jumper pins 7 & 8 (CTS/RTS) together. I do not have a serial port on my computer, so this (or something similar) is my only option for programming. (well, unless I buy a usb->serial adapter, but there's no guarantee that would work, for the same reasons.)
Post Edited (gerundronaut) : 7/25/2009 4:03:12 AM GMT
See this thread: http://forums.parallax.com/showthread.php?p=826193
USB to Serial adapters using the FTDI chip generally work. Parallax uses this chip for the adapters they sell. I've also used a Keyspan High Speed Serial Adapter for years with Stamps and Propellers without problems.
In my case, the command is going out, but the response (excluding the echo) is showing as char "W", as in "Waiting for reset...", from the looping program that's running on the BS2 right now. I've modified the bstamp_run program to flood the chip with "B"'s, but the chip never responds with anything but echo and the constant "Waiting for reset..." program. Since it's just a single 8-bit byte, what timing issues could be coming up?
Do you have more technical details about why the chip is not responding to the command? About the timing it expects?
Post Edited (gerundronaut) : 7/25/2009 5:29:01 PM GMT
This is explained in "Basic Stamp Programming Protocol" a part of the Tokenizer documentation
The reset is also described in the same documentation and is a combination of a pulse on the DTR line and a break state of the TX line.
The timing as a whole is very fine and as far as I know unachievable over a rf link.
I have toyed with the idea of using an additional Stamp attached to the "target" Stamp and used as a programming module but have yet to put it into action
Some·of my thoughts have been guided by Tracy Allen's documentation at the following link http://www.emesystems.com/BS2clone.htm
Jeff T.
FWIW, I was referring to http://bstamp.sourceforge.net/ .
