Boe-Bot, FrequencySweep.bs2
Hi the specialists, when I run FrequencySweep.bs2 herewith attached from Appendix G, page 329 of Robotics with the Boe-Bot, the last "data" superimpose the "Initialization" and first "data" on the screen of Debug Terminal. Is something lacks before or after the two DEBUG in main routine?
Thank you in advance an best regards. MichelB
P.S.: Sorry for my poor English.
Nothing is wrong with your code, it is probably the size of your Debug Terminal. When using the CRSRXY command, the cursor positions depend on the size of the Debug Terminal Window. Once the code hits the bottom of the screen, its considered "out of range" and the text wraps back around. Try maximizing your Debug Terminal and see if that fixes the problem.
- Jessica
Jessica Uelmen
Education Department
