Sending and String Variable to the PINK module
Hello All,·
I am using a BS2P4 with the Pink module and am wanting to send UDP messages of a string of·variables to·an awaiting syslog server.
The issue I have is "how do I fill in the line SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBM:MachineID,[noparse][[/noparse]spd1var],;", CLS]· with my varialbles that I have defined"? I have attached the code that I have so far.
The string that my syslog server is looking for is "MachineID,var,var,;". I do not have the MachineID defined, cause I will just hard code that into the string, if possible.
I am using this to get·run time data and submitting it to a Access database. ··
Not sure if this was the best use of code, but it works.
' {$STAMP BS2p} ' {$PBASIC 2.5} ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- RX PIN 14 ' Serial Receieve Pin --> PINK.TX TX PIN 15 ' Serial Transmit Pin --> PINK.RX SPD1 PIN 1 ' Speed 1 Active Input AUTO PIN 6 ' Automaic Mode Active COMP PIN 7 ' Program Complete ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- Baud CON 240 ' 9600 bps (BS2p) ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- nbvar VAR Word ' PINK Data Variable spd1var VAR Word ' Speed 1 Variable FOR time COUNT trtvar VAR Word ' trtvar Variable for TotalRunTime COUNT ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Start: trtvar = 0 spd1var = 0 Main: PAUSE 1000 INPUT AUTO 'Read pin 1 to see if in Auto Mode or Run (Pin 6) IF (AUTO = 1) THEN trtvar = trtvar + 1 'Increment Total Run Time value INPUT SPD1 'Read if High speed value is used (High=1 or Low=0) (Pin 1) IF (SPD1=1) THEN spd1var = spd1var + 1 'Increment High speed time value ELSE ENDIF DEBUG DEC trtvar, CR 'Show that the values are incrementing, Testing only DEBUG DEC spd1var, CR 'Show that the values are incrementing, Testing only ELSE GOTO Main 'Goto Main without incrementing trtvar ENDIF 'If program is complete submit data srting INPUT COMP IF (COMP=1) THEN GOTO Submit ELSE GOTO Main ENDIF Submit: SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBI:10.119.3.8", CLS] 'UDP IP address of syslog server SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBM:"] SEROUT TX, Baud, [noparse][[/noparse]"MachineID,"] 'UDP message sent to syslog server SEROUT TX, Baud, [noparse][[/noparse] DEC trtvar] SEROUT TX, Baud, [noparse][[/noparse]","] SEROUT TX, Baud, [noparse][[/noparse] DEC spd1var] SEROUT TX, Baud, [noparse][[/noparse]",;",CLS] SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBP:10000", CLS] 'UDP port of syslog server SEROUT TX, Baud, [noparse][[/noparse]"!NB0SB"] 'Send UDP MessagePost Edited (Robert Crouch) : 7/25/2009 2:56:45 AM GMT
