Movement sensor turns on light
There is a light in the staircase outside our apartment, and for some reason I never get to change the lightbulb (to my wife's irritation, and my annoyance
So I thought I'd make a timer/relay circuit with the PIR sensor to have the light go on when there is movement in the staircase.
This timer is easy to build and requires just a few components. In fact, the most expensive part of the circuit is the 12V battery replacer!
The main parts of the circuit are:
* PIR sensor from Parallax. This device outputs a high signal when it senses movement
* 555 Timer. Easy to use and cheap IC to control timing.
* 7805 Regulator. To reduce 12V to 5V for some parts of the circuits.
* 12V relay to switch the mains electricity on
It took me about 10 hours to complete, including attachment to the wall and mains electricity.
Since I don't have access to PCB's, I just left the whole thing on a breadboard, inside a wooden box I found in the atic.
I have a 10ohm resistor at R1, so the light stays on about 2 minutes.
Don't worry. Be happy
.So I thought I'd make a timer/relay circuit with the PIR sensor to have the light go on when there is movement in the staircase.
Attached picture of what it looks like in the hallway. You can see the PIR sensor sticking out at the bottom.
Last post I said 10ohm, I meant 10Mohm for R1.
The transistors T1 and T2 can be replaced with any general purpose NPN transostors.
James
