Another Newbie...
I have zero experience. Searching the forums it seems like the consensus is to start out with a BS2 kit. Anybody care to suggest which one is best for me? I'm an old Chemical Engineer. Last class to program with punch cards...also FORTRAN and Basic. I haven't programmed anything but the VCR in 18 years. I assume that blinking an LED is today's version of "Hello World". Of course the project I have in mind...once I get educated...will require four motor controllers and 3 relay switches. If I can get that working, I'll eventually want to add some additional sensors and data logging.
I realize that I need to crawl first.
Carl
Carl
Parallax posesses power beyond belief.
Believe in it.
Visit me at
http://jrelectromech.services.officelive.com/default.aspx
All hail punch cards and FORTRAN (with WATFOR and WATFIV)!
You'll find PBASIC easy to get back into as has a somewhat simplified syntax than the older versions.
A good starter combo is the Board or Education and a BS2 simply because it has a prototyping board built in. I started with the BS2 and the Carrier Board because I already had a separate proto board. Both can get you going on batteries but you'll want to move to a plug in source fairly soon.
As mentioned, the free "What's a Microcontroller" and "Stampworks" will give you lots of ideas and solutions as you come up to speed.
And, this forum will be the place to ask about anything Stampwise.
Cheers,
Tom Sisk
http://www.siskconsult.com
