Parallax GPS — Parallax Forums
Parallax GPS
Chester SegalaChester Segala Posts: 3
edited 2009-07-24 05:19 in General Discussion
I am using the Parallax GPS to calculate the distance between two points.· Everything works fine except for the accuracy of the GPS.· The distance varies by as much as 25 yards standing in the same place. ·Has anyone done this? and any suggestions?
Chester Segala
    edited 2009-07-22 22:59
    That's normal. The highest accuracy of the GPS system is available only to the US military. The only way to improve this for a civilian application is to have a fixed transmitter at a precisely known location nearby that sends a correction factor to the portable unit. That's what's used in some agricultural applications.
  • Chester SegalaChester Segala Posts: 3
    edited 2009-07-23 03:10
    Mike, thanks for the reply.· I made a portable unit for my golf cart.· I entered the location of all the greens so I could display the distance from my last shot and to the green.· It works fine except the data from the GPS is not accurate enough.· I know they make commercial units that do this.· I wonder how they get their accuracy.
    Any ideas?
    Chester Segala
    edited 2009-07-23 04:27
    You can get accuracy down to 1 meter with a GPS that is enabled with WAAS. Garmin sells several that have this feature. For the golf course, I would recommend a Garmin eTrex H for under $100
    Andrew Williams
    WBA Consulting
    IT / Web / PCB / Audio
    edited 2009-07-23 10:51
    Andrew Williams, thank you for the advice. I would like to buy a GPS module like the Parallax GPS that I can control with a microcontroller so I can write my own program. I have that now, but as I said the accuracy isn't there. I see that the eTrex H uses WAAS to improve accuracy. I guess what I have to find is a GPS module that is WAAS enabled.
    Chester Segala
  • LeonLeon Posts: 7,620
    edited 2009-07-23 11:04
    Try u-blox.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • SRLMSRLM Posts: 5,045
    The Parallax GPS already has WAAS.
