pullup resistors value recommendation?
I want to pull up resistors for the following scenarios:
1) to interface to CMOS open collector outputs (10khz range) pull up to 3.3V
2) to interface to TTL open collector logic (pull up high value to +5V)
Any suggestions on a value?· I've seen 1k or 4.7k as common.
Thanks!
Thanks!
You can have anything between 1k to 10k or even 1M.
It's just a question of speed and noise immunity.
You'll always be on the save side if you look at how much current the device can sink/source and stay at about 30..50% of that.
The rest is simple math: U = R * I
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
10K for pull ups and 4.7K series resistors for 5V to Propeller input interface. The I2C
signals are an exception, I use 2.2K pull ups for fast signal transitions.
