OT: 1N4157 alternative
Hi All,
Sorry this is not really a Prop centered question!
Can anyone suggest an alternative to the 1N4157 diode? (Which I could source from RS components)
Thanks [noparse]:)[/noparse]
Alec
-Alec
Velden in N scale
Alec
-Alec
Velden in N scale
Is a stabistor a specific type of zener, or simply a name for a zener which meets a set of electrical specs?
Reason I ask is i'd prefer to use a drop in replacement (i.e. another stabistor) rather than an alternative.
Thanks for the help!
-Alec
Velden in N scale
Re:source from RS components)
They carry NTE parts but if it's not a stock item they can probably order it for you.
Replace part.... With NTE part.... Product Line
1N4157 NTE177 Semiconductor
Aka: CosmicBob
I must be blind! I can't find NTE177 anywhere on RS's website?
-Alec
Velden in N scale
docs-asia.electrocomponents.com/webdocs/0733/0900766b8073397e.pdf
-Alec
Velden in N scale
Post Edited (Basil) : 7/22/2009 12:50:27 AM GMT
In some transistor amplifiers they were used as a temperature compensator for the transistors, trying to track the Vbe of in this case 3 transistor drops.
If that's what it's doing, then 3 vanilla diodes in series might be what you need. They are still available from Arrow, but good luck if you need just 1, you might be able to get a sample out of them.
If its being a voltage reference, there are better options these days.
This being the case, I haven't got a good understanding of its operations so couldn't tell you what the purpose of the stabistor is.
The circuit is a DC speed controller for a model railroad.*
The output from the stabistor is being fed into the THRESHOLD input of a 555. Heres a snippet from the circuit description:
I wonder if anyone could suggest the purpose of the stabistor with this info?
*Note: My plans of prop based DCC controller have been defered due to the cost associated with fitting my already very expensive German loco's with a very expensive DCC decoder :P
-Alec
Velden in N scale
-Alec
Velden in N scale
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
-Alec
Velden in N scale
