Static Ram for prop
Hi guys , I want to add some static ram to my prop proto board can anyone recommend a chip to use I want to add 1-4 Meg also if anyone has a schematic that would be awesome as well I want to be able to add the ram in the simplest way possible.
do a search.parallax.com on this - topic comes and goes in various flavors
hth
- Howard
BS62LV4006 512KB 55ns DIP32 SRAM (parallel SRAM)
Microchip 23K256 32KB SPI SRAM
Which is also the chip Cluso99 uses for the TriBladeProp - others use it too; it is the only readily available 512KB SRAM chip - but it needs a LOT of pins! Depending on how you want to address it, you will currently need 10-31 pins
The Microchip SPI ram is small, but it only needs four pins - and you can actually use three pins if you tie the DI and DO together.
Products:
http://www.parallax.com/Store/Microcontrollers/PropellerAccessories/tabid/786/CategoryID/85/List/0/Level/a/ProductID/444/Default.aspx?SortField=ProductName,ProductName - 10 pins, you can replace the firmware
http://mikronauts.com/products/morpheus/memplus/ I sell a board that needs at least 21 address bits for 2MB (bus has 24 address bits), -RD, -WR and D0-D7 - for 31..34 pins, however you could use some latches and counters
http://www.machineinteltech.com/Memory_Expansion.html sells a 2MB kit with a PCB that uses 12 Propeller I/O's
There are a few other products on the forums, but I don't think they are available yet - look at Jazzed's and Cluso's posts.
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Post Edited (Bill Henning) : 7/21/2009 9:55:00 PM GMT
This all kind of depends on your specific needs.
The SPI-SRAM offers the lowest pin count and performance for use on one Propeller and is a suitable add-on for the Proto-board.
I have a design in progress that allows around 5MB/s and up to 1MB memory on 16 pins on two modules with one Propeller and is a suitable add-on for the Proto-board.
Have a look here: http://forums.parallax.com/showthread.php?p=811093 ... the more interest the faster I can finish the production design [noparse]:)[/noparse]
I just realized I offered you a schematic and some instructions, but then decided I could not deliver for some reason.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Post Edited (jazzed) : 7/21/2009 10:26:48 PM GMT
since I use lots of I/O for my sensors Mike Green also shot me a reply about using eeproms that I can just fit in the standard socket I might try that as well, I guess from the response I would like to just add one chip for now so the
Microchip 23K256 32KB SPI SRAM seems like the right way to go If I can get that to work I can just keep adding more of them right?
I also tried to wire up the older type eproms the ones with the window you use UV to erase. I used a 2764 but I had so many pins 16 address and 8 data bits I could never get it to read the darn thing .. I did burn a simple spin program into it but could not get the prop to read it right
Jazzed Thanks I figured you got busy like the rest of us , if you do finish it I would love to see/buy one if you are offering them.
I also have a Prop + Sram +microSD pcb (RamBlade which plugs into a Proto Board, etc) coming but alas not getting the time to finish the pcb. I am doing another pcb at the same time, hence the delay. It has a few tricks to get simpler and faster access but requires the whole prop (no latches). Uses a SIL 0.1" 8 pin header. It is fully smt and I am aiming to run it at 120MHz.
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
· Search the Propeller forums (via Google)
