Which edition of the CMU Cam do you have? There are two different versions that would require seperate demo programs. However, Mike touched on a good point, both are available from our web site. Here is a link to the product page for your convenience. If you have the version A (should say on the PCB of the CMU cam), you will need to use the archive files.
CMU Cam:
http://www.parallax.com/Store/Robots/RoboticAccessories/tabid/145/CategoryID/22/List/0/SortField/0/Level/a/ProductID/29/Default.aspx
I hope this helps
Respectfully,
Joshua Donelson
www.parallax.com
