BS2 and relays
I am about to start a project to open a dog door using the basic stamp 2, some sensors, and a linear actuator. I've done a fair bit of research but am stuck on one part. Just a bit of background first though, i am a professional software developer, but am fairly new to BS and electrical engineering. So my question is, will the output voltage on one of the BS2 pins be enough to trigger a relay such as this one: http://www.firgelliauto.com/product_info.php?products_id=28·? From what i understand the voltage that goes to the pins is ~5v, and the relay is execting 12v. Surprisingly, I can't find any examples of people doing this (on google or here), but I would imaging this is a common thing. If this is not possible, how do people accomplish this task (the task being, engaging a linear actuator which requires higher voltage/amps and the ability to reverse the polarity)?
Thanks!
Doug
Thanks!
Doug
There are all kinds of examples available for controlling a relay from a Stamp I/O pin using a switching transistor. For example, download Nuts and Volts Column #6 and have a look at it. Go to the main Parallax webpage and click on the Resources tab. In the list that comes up, click on Nuts and Volts Columns and you'll be taken to the index.
You can reverse the polarity with a 2nd relay (a DPDT - double pole double throw relay) that can be connected to reverse the power.
·The more you learn, the more you find you don't know. It is neverending.· Confucous 550 BC
Your solution will probably save that headache or create a new one [noparse]:)[/noparse]
Here is a discussion of using ULN2003: www.electro-tech-online.com/datasheet-parts-requests/39976-uln2003.html
Don't worry. Be happy
i was working with 12 volt relays to interface to a 120 volt PLC
be careful with stamps and relays make sure you have an anti kickback diode in place to prevent kickback of the collapsing magnetic field cause that could fry your stamp been there done that no fun it was a friends stamp too OOOPS lol
Parallax posesses power beyond belief.
Believe in it.
So my end goal here is to turn give power to an actuator and to be able to reverse the polarity. This is done by controlling the switches on two relays. Most of the actuators that firgelli sells, say that they require 12V and 4amps at full load, which is what I will be toggling through the relays. The relay I posted above says it requires at a minimum of 150amps and later is says that it must be at 12V to trigger the relay. Since the BS output pin is at 5V and ~25amps, the ULN2003 will allow me to control another power source at 50V and 500mA max (of which i only need 12V). So, what i'm struggling with here is it seems like I need 3 different power supplies, 1 for the BS, 1 for the actuator (at 12V 4A), and 1 to trigger the relays, which will go through the ULN chip (12V and <500mA)?
That sound right? Anyway i can simplify my power needs?
Again, I'd like to apologize for my newb questions. I'm not trying to become an expert in this area (yet), and I am under a time crunch.
- Mike: I looked over the columns you suggested but didn't see anything about this specific subject? Which column in volume 6 were you referring to?
- Lab Rat: Do you have any links to example diodes, I didn't find much when i googled that.
You can also use what's called an H-bridge. This is a set of 4 transistors with controlling logic that can turn power on and off and can reverse the polarity of its output. There are some integrated versions like the L293 that Parallax uses in their Professional Development Board. Google "wiki h-bridge" for a description and some examples and links to further information.
http://library.solarbotics.net/circuits/driver_4varHbridge.html
Have a good one.
Bob
Believe in it.
I was able to find this chip:
http://robokitsworld.com/index.php?main_page=product_info&products_id=79&zenid=n6k4rmeik040lmlkim2k6lonn7
Spec: http://www.robokits.co.in/datasheets/l293d.pdf
which looks similar to chip you mentioned Mike, only it handles more amps. From what I now understand I can toggle the inputs on this chip with the pins from the BS, and I can run a 12V 2A powersupply through the chip to power this guy:
http://www.firgelliauto.com/product_info.php?cPath=79&products_id=131
the chip says it handles 1A and 2A Peak, the actuator runs at <1A under no load and 2A max....since the actuator won't have much load, am I okay here?
1A would be the continuous current rating. Since the actuator is lightly loaded and the no load current is under 1A, you should be fine. Since you're close to the current rating, plan on a little heatsink of some sort. The center ground pins on the package help dissipate heat and, on custom printed circuit boards, are often connected to large area "tabs" of copper.
