DS1302 RAM Rd/Wr constant/address formatting question
I've spent the past hour searching the forum.· I KNOW I've seen the answer to this somewhere - perhaps an N&V column - but I've opened and read all the likely candidates there ("getting real with the DS1302", etc).· So in frustration, I've gotta ask....
I'm looking for the *description* of how the address and the·constant to read/write to that address are actually operated on by the DS1302.· The specific lines of code I am seeking to better understand is:
reg = WrRam | (index << 1)
and
reg = RdRam | (index << 1)
Where RdRam is a constant = $C0 and WrRam = $C1.
While I "know" that this means that the constant RdRam or WrRam are OR'd with the index value for the byte to be written to and shifted left 1 bit (???), I'm not really *understanding* what's happening.· And I'd like to...
Thanks for any help!
Dave
and
Dave
First thing is to notify the DS1302 that you want to write and to which address you want to write to.
WrRam ($C0)·is the template for your command , the gap you have to fill in is the address which is bit 1 through 5 ( marked in·red )
11000000
The variable index is the address you manually enter via the debug screen , so say you entered 23 in binary thats 10111 ( the 5 bits we need )
Next we shift the value 23 left by 1 ( index<<1 ) giving 101110 .
Now when we OR index with WrRam we have the write command containing our address (which is now held by "reg")
11000000
OR
00101110
reg= 11101110
Jeff T.
It seems so simple now... Don't know why it seemed so confusing before...
Thanks again!
Dave X
Parallax Engineering
