Serial to USB converters
· Hi All
· I just picked up a BOE stamp2 at a local HAM fest. Its a serial BOE and I
have no serial ports on my PC I have a Serial to USB, but I'm not sure if it
is working. I put a 9v battery on and LED lights.
Any help or thoughs on getting started.
Ken
Ken
Make sure you have the proper (and most recent) USB to Serial driver for your device. Check the manufacturer's website to be sure.
Try to compile and run one of the sample programs. Either your adapter will work or it won't. Pretty much any adapter that uses the FTDI chip will work. Some other adapters will also work. There's no exhaustive list. The Identify menu choice in the Stamp Editor will test the connection (and the Stamp). You'll have to have power connected to the Stamp for Identify to work.
Ken
http://www.parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/40/List/0/Level/a/ProductID/379/Default.aspx?SortField=ProductName,ProductName
Dave
Dave Andreae
Parallax Tech Support·
I'm with you on this one. The Parallax " USB to 232 " is the way to go.
I too had to learn this the hard way.
"A hard head will only lead to a soft back!"
______________$WMc%____________
The Truth is out there············································ BoogerWoods, FL. USA
I have my own question. I have been using the serial port to communicate with chips, which is good because I use C#.NET 2005 which has a drag and drop serial port control which means you only have to add a few lines of code. I was using this to listen for anyincoming data being sent via the chip and then when my c# program recieved data i would insert the data into ACCESS or SQL Server Express.
I used USB to SERIAL converters to add extra chips and they all worked well.
I dont know much at all about the SX/B yet, but the started kit comes with a USB Cable. Now USB comms is not 'Drag and Drop' and much more complicated. If I were to eventually try out the SX/B (much later) , I am not sure what I'll do to communicate with the chip.
Or Maybe I can just recieve the the data via the USB and save as a file and then write a C# program to process that file ?
You are correct, the USB to Serial adapter we have uses the FTDI chipset; the FT232RL to be exact. There are drivers available from our web site, and from the FTDI web site (www.ftdichip.com) if you are using Mac or another OS. For anyone who may need a link to the drivers, here is a link to the installer for Windows 2K to Vista 64.
FTDI USB Drivers:
http://www.parallax.com/Portals/0/Downloads/sw/uty/USBDriverInstallerV2.04.16.exe
I hope this helps and clarifies,
Respectfully,
Joshua Donelson
www.parallax.com
