Voltage divider array IC
catostay
I would like to give a higher voltage to to input ports of the propeller and I am looking for an IC to protect the input ports with a voltage divider. I am using right now a 10k resistor to GND and a 1K resistor to a Propeller pin which works fine. I however need 8 voltage dividers for 8 input ports and to save some assembly time I was looking for an IC which makes life easier.
I looked at Mouser and Digikey but so far I was not able to find the right IC because I don't know what I should look for.
Does anyone know about any voltage divider IC which I could use?
Thanks for you help
Post Edited (catostay) : 7/19/2009 1:41:17 AM GMT
Thanks for you help
Here's one 1K network in a DIP package for an example:
www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMvrmc6UYKmaNWQksCmc3yhh%2fpyZolAtSWE%3d
Thank for you fast answer. Yes I know about the resistor arrays and I tried to use them but it is very difficult to manage a voltage divider on a single sided board. I also would like to save some space on the board. One IC would be better than one and definitely better that 16 resistors on the board.
Post Edited (catostay) : 7/19/2009 1:52:18 AM GMT
