WORD arrays in SXB OK? — Parallax Forums
PJAllenPJAllen BannedPosts: 5,065
edited 2009-07-18 21:45 in General Discussion
section··VAR· WORD(5)
--> INVALID NUMBER OF PARAMETERS
  • JonnyMacJonnyMac Posts: 9,809
    edited 2009-07-18 17:16
    SX/B has never supported arrays of Words. What do you want to do, specifically?
    edited 2009-07-18 17:38
    Well, that's that --·I'll have to do it in two bytes then.· It'd be nip_&-tuck with a WORD array.
    [noparse][[/noparse] How do you eat an elephant?· One byte at a time! ]
    Depending on what you need the code to do you can define words within an array:
    temps           VAR     Byte (8)
     tmpW1          VAR     Word @ temps(0)
     tmpW2          VAR     Word @ temps(2)
     tmpW3          VAR     Word @ temps(4)
     tmpW4          VAR     Word @ temps(6)
    To use them like normal variables, though, you have to use BANK @temps, run your code, and then use BANK to get back to the "normal" variables bank. Again, it just depends on what you're wanting to do.
