Exact RS232 settings used by Javelin IDE
Hello,
I'm trying to connect to my stamp to program it wirelessly using 802.11
I have a gridconnect WI232 that handles the wireless transfer of data from my laptop to the Javelin stamp.· I have it setup where I can telnet into the stamp and get data from a running program so I know the connection is working to some extent.
However,· when I try to connect to the stamp with the Javelin IDE it can't find it.· I'm sure there must be some RS232 settings that aren't being handled correctly by the WI232 device.· There are a lot of options on that device,· I'm sure I could program it to do what I need if I only knew what I needed.
Does someone know the EXACT serial communications setup between the Javelin IDE and the Javelin Stamp when it's connected via RS232?
Thanks in advance,
-Travis
Thanks in advance,
-Travis
RX, TX and DTR. The baudrate is 28800.
There is a hardware echo: anything sent from the pc to the javelin
is directly echoed back to the pc.
regards peter
Parallax Engineering
