Parallax BS2 input/output from iphone with blue tooth or WiFi
Is there any way to receive input signals from the iphone on a bs2 with a eb500 blue tooth module? I've been researching the subject and it seems it can be done, but a PC is necessary. If the iphone and bs2 both have bluetooth shouldn't they be able to communicate?
If wireless communication isn't possible, would there be a way to connect serially?
I'm interested in getting inputs from the iphone to control a mid-size motor via the HB-25. Also, I'd like to get battery level data to read out on the iphone.
Any thoughts?
Any thoughts?
I am using the BlueSmirf Gold from Sparkfun with 100m range.
Don't worry. Be happy
A highly detailed user Manuel can be downloaded from www.a7eng.com for the eb500, its 117Pg.s and will help you make the iphone talk to the eb500.
_________$WMc%___________
The Truth is out there············································ BoogerWoods, FL. USA
The same thing currently applies to serial I/O. You'd have to build your own serial interface circuitry and you'd have to write your own software to use it. Again, this is likely to change in the future now that there's some APIs in the iPhone SDK that will allow I/O via the dock connector, but there's nothing yet.
