Small hydraulic servo control valves-BS2 project
Hello All
I'm looking for a small hydraulic servo control valve. Low cost is more of what I'm after.
Voltage range somewhere between 5 and 25 volts DC.
Any Links or Ideas would be great.
___________$WMc%__________
The Truth is out there············································ BoogerWoods, FL. USA
Mike2545
This message sent to you on 100% recycled electrons.
-dan
Not cheap is what I keep runnig across. $400 is the cheapest I've found, I need two of them.
____Thanks Again_____$WMc%___________
I have 2 Moog servo valves, model 974C, p/n M-6574. The were overhauled by Moog in 1964 and do not appear to have been used since. I have not been able to find any docs on these. If you can find docs and these would work for you I would let them go for a reasonable price.
Rick
But the Hyro rout is gust to expensive for this project.
I'm going with 24volt DC motors.
