RS232 connection to Stamp, exact settings
Hello,
I'm trying to connect to my stamp to program it wirelessly using 802.11
I have a gridconnect WI232 that handles the wireless transfer of data from my laptop to the Javelin stamp.· I have it setup where I can telnet into the stamp and get data from a running program so I know the connection is working to some extent.
However,· when I try to connect to the stamp with the Javelin IDE it can't find it.· I'm sure there must be some RS232 settings that aren't being handled correctly by the WI232 device.· There are a lot of options on that device,· I'm sure I could program it to do what I need if I only knew what I needed.
Does someone know the EXACT serial communications setup between the Javelin IDE and the Javelin Stamp when it's connected via RS232?
Thanks in advance,
-Travis
Thanks in advance,
-Travis
Mike2545
This message sent to you on 100% recycled electrons.
