SHARP GP2Y0A02YK0F Sensor Question
Hi
I want to use the SHARP GP2Y0A02YK0F sensor with the Basic Stamp.· http://document.sharpsma.com/files/gp2y0a02yk_e.pdf·how would I connect this sensor to the Basic2, directly or do I need to use a A/D ·?··
Jan
Jan
If you're interested, look at www.emesystems.com. Select the "app-notes" link and look at the discussion on the RCTIME statement.
To chime in really quick, there are various types of ADC modules that you could use; depending on the speed and resolution that you need, would determine which ADC to use. For example, there is a 8-bit and 12-bit ADC available from Parallax which are easy to implement (I believe there is sample code for both). Here is a link for you to review to see if either of these will work for your application.
ADC Modules:
http://www.parallax.com/tabid/613/List/0/CategoryID/78/Level/a/SortField/0/Default.aspx
I hope this helps,
Respectfully,
Joshua Donelson
www.parallax.com
