System vars & PINK
Hello,
I can't set the email variables as default value. All data is lost when power is cycled.
The first variable (email to) is always empty when i refresh the system variable page (VV_Show.htm)
Can i fix this problem?
Having Firmware Version: SB70 Parallax Web server 1.32
Last year i had to get a new one from antratek, couldn't erase files trough ftp.
PINKdocs V2.1 said...
The PINK Module has 100 general purpose variables and 18 dedicated system variables. Each variable can
store up to 64 bytes max. The first 20 general purpose variables (0 through 19) can be written to flash memory
as power-on defaults. The remaining general purpose variables (20 through 99) are RAM variables only and the
I went throught this fairly recently as I have an application where I wanted to be able to write to vars 0 - 19 in an application to allow data persistence in my application through a power cycle, but currently it cannot be done. There is talk of a firmware revision coming up, and I have expressed my sincere hopes that this can be done - but I have heard nothing on this as even a possibility. It would be VERY useful to have a separate way of writing to flash vars, from either the stamp or the embedded web code. We'll see.
Please let me know if I have properly answered your question.
Dave X
Yes i know, that's the way i set the vars.
The problem is only the first var (Nb_varET : email To)
Sometimes it will be set during power cycling. but almost id didn't.
Dave X
Are you displaying the variable on a web page? If so, that could be the issue. A small bug was discovered several months ago where if the first e-mail variable was displayed on the web page it would cause it to be reset. This does not affect the default saved in flash memory, just what it in RAM at the time. The bug has been corrected in current firmware.
Parallax Engineering
I have made some tests here.
FIlled in the e-mail vars, programmed a bs2 so that the pink sends an email when i plugin the power.
The first 2 times i had to reconnect the power, no email was sent.
Third time: bingo! an email was sent. Every time i push the reset button (bs2) an email was sent.
Now i looked at the VV_Show.htm -page: mailTo var was empty.
Looks like the bug you described.
but I am unclear if during any of that the variable in question is being displayed on a user web page hosted by the PINK module. => no. (not anymore) [noparse]:)[/noparse]
Yeah typically a user wouldn’t be displaying those variable on a page, although there are several types of applications where it is necessary as pointed out by the forum member who originally discovered this little bug. If your application requires you to display the variable then you can arrange as before to have your PINK module swapped out for one with newer firmware in which the issue has been fixed. Take care.
