MP3 To WAV Converter? — Parallax Forums
Dan TaylorDan Taylor Posts: 207
edited 2009-07-16 19:25 in Propeller 1
Hey,
Could someone post a MP3 to WAV Converter that has worked for you? I would much appreciate it!
Dan Taylor
  • VaatiVaati Posts: 712
    edited 2009-07-16 18:48
    Use the programs I listed in this thread.· Follow those instructions to convert mp3 to wav...
    Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
    *-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
  • RaymanRayman Posts: 16,268
    edited 2009-07-16 19:18
    I used to have a bunch of command line tools, but these day's I just use Nero "WaveEditor".
    If you have a PC with a CDROM there's a good chance it came with some program similar to "WaveEditor" mixed in with your CDROM software...
  • Dan TaylorDan Taylor Posts: 207
    edited 2009-07-16 19:20
    I am having some trouble converting. When I side-click my song and supposed to click Convert audio format, there is no such button. There is only Convert to Wav... I tried it and nothing happened. I am using Vista so the format may be different.
    Thanks for any help!
    Dan Taylor
    Post Edited (Dan Taylor) : 7/16/2009 8:29:03 PM GMT
  • Tired2Tired2 Posts: 29
    If you only have few to convert (not sure if it supports command line, probably does though), try audacity:
    http://audacity.sourceforge.net/
    It does a lot more than convert, which you may find you'll end up needing to do anyway. (editing, levels, filters, etc)
    Just open the MP3, and then save it out as a wave. I think you'll have to go out and install lame.dll to use mp3, but it only takes a second.
