DS1302 Xtal? — Parallax Forums
DS1302 Xtal?
VaatiVaati Posts: 712
edited 2009-07-16 19:58 in General Discussion
Will this work in place of the normal cylindrical xtal for the DS1302?
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
  • LeonLeon Posts: 7,620
    edited 2009-07-16 16:38
    It should be OK. You need to connect it the right pin (X1).
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • VaatiVaati Posts: 712
    edited 2009-07-16 16:40
    So, it is a "drop in" replacement for the normal xtal? Obviously, I would have to connect the pins correctly...
    The reason I ask is because on page 7 of that datasheet, it shows a circuit with the chip AND a 32.768 clock xtal, so...
    edited 2009-07-16 19:57
    Just feed the output into X1.
    Leon
    Okay, then I can get to using my RTC!
    Thanks.
