Save that for later...
CumQuaT
Hello hello,
Still kinda new to the Propeller, but I'm very slowly getting the hang of it, and enjoying the fact that I'm becoming more and more impressed the more I learn...
I'm using the standard by-the-book Propeller circuit with the standard 8 pin 32k EEPROM chip, and I'd like to be able to save a variable to the EEPROM so that the next time I turn my circuit on, it will be able to retrieve the data for later.
Is there an easy way to do this? Does anyone have a code example? Do I need more parts?
Any help would be great! Thanks!
Who are you, and why are you reading my signature?
Check out Andy Lindsay's excellent application notes and example Propeller code on EEPROM Datalogging
http://forums.parallax.com/showthread.php?p=678271
Beau Schwabe
IC Layout Engineer
Absolutely, and it works a treat. The problem is each time you download a revised program you lose the data (but that happens no matter where you store the variable in the bottom 32k anyway)
Release the hounds!
It's a bit of a pain (because of extra steps required), but one could use 3PClient + 3PConv to flash only the part that actually contains code. You could also flash the persistent vars in the same go.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Yes and no.. It's quite likely that if any code is changed the variables will be located in different places. Remember the VAR block begins long aligned after all the DAT and spin code. If the code changes size over or under a long boundary the position of the VAR block will change anyway.
If you are going to do it your way, the best way to do it is start at $7FFF and work down. Then your data is always in a fixed position and you just load the eeprom with the program up to that point. As long as you don't smack into it with the stack you are all good to go.
Release the hounds!
I meant to have the persistent var well outside of the reach of the program image and in a fixed position.
This requires to read the var by some EEPROM-routines.
You have the least headaches with a bigger EEPROM and writing the data starting at 0x8000.
One might try my NVVar (use the seach function). It's not very simple, but has the advantage to detect new versions of the persitent vars and being able to handle that.
Nick
YADRO
eeprom.VarBackup(@values, @values[noparse][[/noparse]31] + 3) ‘ Backup
eeprom.VarRestore(@values, @values[noparse][[/noparse]31] + 3) ‘ Restore
Right. The only time it looks at the checksum is immediately after download to ram.
Release the hounds!
