USB to Serial adaptor
I have a PC with both serial ports and USB ports.· I am using a USB-Serial adaptor to use my Parallax servo controller on my USB port.· With the USB to serial adaptor installed, can I still use my serial ports normally to communicate with my BS2?· I have hooked my oscilloscope up to my serial port and send out a digit and what I get on my scope·is not RS-232.· Is this because of the USB-Serial adaptor software or something else?
If you have a serial port on the PC, it has to be RS232. Are you looking at the transmit / ground lines? Some PC serial ports are not quite standard, particularly some laptops. What are you actually seeing?
There's nothing like a new idea and a warm soldering iron.
I'd setup a test so you know good data is flowing between two devices (stamp-Stamp or computer to stamp) then hook up the scope. Don't forget real rs-232 voltage levels are "upside down".
cheers,
Tom Sisk
http://www.siskconsult.com
