How to send one bit at a time
Hello all! I am using the Basic Stamp 2 homework board and I would like to know, how can I output 1 bit at a time of a 16 bit word variable? I know how to use SHIFTOUT, but that sends all of the data. I need to send data, wait for an input pulse and if it gets it, send another bit. Can this be done? If so, how?
Let's say you have your I/O pin defined as "SIGNAL PIN 6". You can have a FOR / NEXT loop that does "SIGNAL = FOO.BIT(i)" then waits for your input pulse before going on to the next bit.
·Actually you get "Expected a variable modifier"· using FOO.BIT(I) -·you need to reference FOO.BIT0(i) or .... BIT15(i)
Post Edited (ronczap) : 7/16/2009 12:50:57 AM GMT
Look at the BASIC Stamp Syntax and Reference Manual, pages 85-91.
