pbasic interpreter problem "No BASIC stamps found"
Hello All,
I purchased a pbasic interpreter chip for the BS2 in the 28-DIP·package in an effort to make my own BASIC stamp 2. So far, I have tried two designs: the OEM stamp schematic that I found on the website, and another schematic online that uses a MAX232 serial driver/receiver rather than all the transistors and resistors found on the OEM schematic.
OEM Schematic:
http://www.parallax.com/Portals/0/Downloads/docs/prod/schem/BS2Oem.pdf
MAX232 Schematic:
http://www.weethet.nl/images/basicstamp/homebrew.gif
So far, using both designs, when I hook up the stamp to the computer, the loop and echo return "yes", but when I go to program the stamp, a "No BASIC stamps found" box pops up. I've tried turning off FIFO buffers to no avail. I've checked that I'm getting +5v to all the chips. I am not using the brown-out detector, but I don't see why this would be an issue. The only difference between the schematics I can find besides the serial interface is that the OEM schematic does not have a pull-up resistor on the clock pin of the EEPROM, the OEM uses a resonator, not a crystal,·the MAX232 schematic has an optional reset switch, a diode on the receiver pin of the DB9 connector,·and the numbering of the I/O pins is different. So far, I've tried removing the pull up resistor on the MAX232 board; this did nothing. I've checked my wiring several times. The only things·I can think of that might be the issue are a.) I need to use an earlier version of the stamp software. b.) my pbasic interpreter is bad. c.) I need to use a ceramic resonator like the real stamps use, rather than a crystal. d.) my eeprom is bad.
I would like to get this thing working, any help would be appreciated. Thanks!
OEM Schematic:
MAX232 Schematic:
Check for pin 2 to pin 2 and pin 3 to pin 3 continuity.
Than to lessen your frustration check the other tread ... TROUBLED.
Cheesr Vaclav
the echo and loop return is only checking if pins 6 and 7 are connected on the db-9 connector.
