libraries and packages in Java IDE
Hello,
I am trying to do something very simple but cannot manage to figure it out. I have my javelin connected to the HM55B compass. I would like to download the code online to test the compass, which I've gotten to work with my basic stamp. Up until this point, I have written all my own code for the javelin and never used any of the libraries or other cool/useful code out there.
My problems / questions are as follows:
JIDE compiler does not recognize the package
I need to import various libraries like stamp/math/IntegerMath. I am getting misplaced package / non-existent entity errors.
If some one could walk me through downloading a package and importing classes, that would be great. I know this is pretty basic but I haven't been able to find documentation out there either. If anyone knows of documentation that I've over looked, please give me the heads up.
Emily
Emily
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/
That is basically the Javelin IDE installation folder of your PC.
You will find the folders lib and Projects, just as on your PC.
The folder layout is identical to the PC folder layout,
which makes it easy to install packages.
If you go here:
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/math/
you are in fact looking at package stamp.math
which is located in folder [noparse][[/noparse]javelin installpath]\lib\stamp\math
If you don't have the folders on your PC but that are on the Yahoo group,
then make them on your PC using the EXACT same folder names (upper/lowercase letters)
and copy the files from Yahoo to their identical PC folder.
Now the files are ready to be imported by your programs.
regards peter
[noparse][[/noparse]Java Error]HM55B.java(5): Error: Could not find package named:
C:\Program Files\Parallax Inc\Javelin Stamp IDE\lib/stamp/peripheral/sensor/compass/HM55B or |
C:\Program Files\Parallax Inc\Javelin Stamp IDE\Projects/stamp/peripheral/sensor/compass/HM55B|
[noparse][[/noparse]Java Error}HM55B.java(7): Error:"stamp/math/IntegerMath" is either a misplaced package name or a non-existent entity
[noparse][[/noparse]Java Error]HM55B.java(86): Error:"IntegerMath" is either a misplaced package name or a non-existent entity
In both these errors, the HM55B one and the IntegerMath, the beginning top lines of my code read:
package stamp.peripheral.sensor.compass.HM55B;
import stamp.core.*;
import stamp.math.IntegerMath;
I am using the JIDE. I really don't get this error at all. Packaging in java is always a little messy but I'm not sure what trouble shooting I can still do.
c:\program files\Parallax Inc\Javelin Stamp IDE\lib\stamp\peripheral\sensor\compass\HM55B
Note the HM55B javafile is located in a folder HM55B
So the HM55B java file must not be placed in the compass folder.
An easy to make mistake.
If you have the file in the correct folder
and still get the error, please post the program
where you import the HM55B file.
To import HM55B you must use
import stamp.peripheral.sensor.compass.HM55B.HM55B;
import stamp.peripheral.sensor.compass.HM55B.*;
Perhaps you are using
import stamp.peripheral.sensor.compass.HM55B;
Also, your own program should not have
unless your program is in the HM55B folder.
Use an import line in your program.
regards peter
Post Edited (Peter Verkaik) : 7/15/2009 8:48:24 PM GMT
