GPS versus GPS + cable
Can anyone tell me why the GPS is sold for 79.99 and the GPS + Cable is sold for 39.99?
Does the one with the cable offer less? Are the GPS's the same?
Dave
Dave Andreae
Parallax Tech Support·
And needed to send that information via email or sms
If you are referring to Latitude & Longitude either unit will provide that. The difference is in the interface and the way the data is presented. The Module has a co-processor and is designed for microcontrollers such as the BASIC Stamp 2 which does not have the resources to handle the large NMEA strings. That module also runs from a 5V supply. The receiver can run from 3.3V-5V and has both RS-232 and line level I/O, but it only outputs raw NMEA data. This means the microcontroller needs to buffer and parse the data to extract the Latitude and Longitude data from it. Take care.
Parallax Engineering
So, in summary, if you have a BS2, you will need the more expensive GPS module. If you have some other Stamp model like the BS2sx, BS2p, BS2pe, or BS2px, you could use the cheaper module, but the programming will be much more complex and it will be slower.
