Could some one tell me after run this routine with the input ON for about five
The project code is below
What I mean by freezes is that the seconds are stop the display light is ON
This happen when you have a power loss and power up the Basic Stamp and Input at the same time
The display light is on when the input = 1 and seconds should be counting
If I turn·OFF the input = 0 and back ON· the Input = 1 then the second start running again
I have an idea that I may have to start the·clock at power up I will see tomorrow when I get home if this is cusing the problem
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 7/14/2009 1:41:40 AM GMT
··Thanks for any·
Sam
At first glance I have some questions…like why are you clearing the write protect register on startup? The DS1302 Demo does this because you keep changing data. Normally when you’re not setting the time or writing data you’d want it in protect mode. But the commands you’re sending right after aren’t clear. They’re listed in binary and have no comment.
I see you commented out a section that was supposed to start the clock, but just so you know that is only necessary when the DS1302 has completely lost power. If you’re using a battery backup you wouldn’t do that.
It’s hard to tell because your code does a bit of jumping about…but it looks like in certain cases you may be exceeding the number of nested GOSUB commands you can have.
Parallax Engineering
It looks like in certain cases you may be exceeding the number of nested GOSUB commands you can have.
Thank You for point this out to me I will see if I can put two routine together and only have four GOSUBs
What do you do if you can not·put two routines·together and you have more than four GOSUBs what can you do in that case
Can you give an example
Thanks for the Info
·Normally when you’re not setting the time or writing data you’d want it in protect mode.
This was something that I was trying from one of the Demo that was in the Stamp Works and forgot to take it out
·But the commands you’re sending right after aren’t clear.
··Thanks for any·
Sam
