Bits and bobs: Bits and Bytes — Parallax Forums
HughHugh Posts: 362
edited 2009-07-14 12:47 in Propeller 1
This is probably a silly question, so feel free to provide a silly answer:
Q: Is there any easy way to convert a byte to bits, i.e., a byte with decimal value '38' to '00100110'?
Bitwise encode isn't quite it. I could write some code to do it, but an indigenous spin function would be much more preferable!
Hugh
Hugh - the thinking woman's Geoffrey Pyke.
  • KyeKye Posts: 2,200
    edited 2009-07-13 18:19
    Um, your talking about strings right?
    If so then:
    VAR
    byte binaryCharacters[noparse][[/noparse]33]
    PUB numberToBinary(number, length) '' 5 Stack Longs
    '' │ Converts an integer number to the binary string of that number padded with zeros.                                        │
    '' │ Returns a pointer to the converted string.        │
    '' │ Number - A 32 bit signed integer number to be converted to a string.                                                     │
    '' │ Length - The length of the converted string, negative numbers need a length of 32 for sign extension.                    │
      repeat result from 31 to 0
        binaryCharacters[noparse][[/noparse]result] := ((number & $1) + "0")
        number >>= 1
      return @binaryCharacters[noparse][[/noparse](32 - ((length <# 32) #> 0))]
    Otherwise you should realize that '38' and '00100110' are the exact same thing, unless they are strings.
    Nyamekye,
  • rokickirokicki Posts: 1,000
    Can you explain more fully what you are trying to do? A "byte" is just a convenient word we use for a
    collection of eight binary bits, so the "conversion" is implicit.
    Are you looking for the ASCII representation of the binary expansion, perhaps?
  • HughHugh Posts: 362
    edited 2009-07-13 18:29
    Sorry.
    I meant that iff I have a byte with a value of '38', can I easily determine the value of Bit 3, Bit 7, Bit 'n', etc., is?
    I think Kye's solution is sufficiently simple and zippy, but I didn't know whether there was a spin single command / function to do the same thing - it would appear not!
    Thanks!
    edited 2009-07-13 18:43
    Oh, well then my solution will not be useful to you.
    There is no command for what you want to do here.
    ((byte >> n) & 1) is the way to do this.
    As in if I want bit 3 (from bit 7 to bit 0)·then I do.
    ((byte >> 3) & 1)
    Nyamekye,
  • JonnyMacJonnyMac Posts: 9,851
    edited 2009-07-13 19:05
    You could code Kye's suggestion into a generalized method:
    pub bittest(value, bit)
      return (value & (1 << bit)) > 0
    This returns true if the bit is set, false if it is not.
    [noparse][[/noparse]Edit] If you want to test for multiple bits on, you could do this:
    masktest(value, mask)
      return (value & mask) == mask
    So if you want to check if bits 0, 3, and 7 of a value are set you could do this:
    status := masktest(somevar, %10001001)
    Post Edited (JonnyMac) : 7/13/2009 7:19:17 PM GMT
    edited 2009-07-13 19:10
    More than good enough for me - Mr Lazy!
    edited 2009-07-13 19:32
    Here are a couple other ways: one which uses an array, for when the bit number is a variable; the other, using constants, for when the bit number is a constant.
    [b]CON[/b]
      [b]_clkmode[/b]      = [b]xtal1[/b] + [b]pll16x[/b]
      [b]_xinfreq[/b]      = 5_000_000
      bit0          = |<  0
      bit1          = |<  1
      bit30         = |< 30
      bit31         = |< 31
    [b]VAR[/b]
      [b]long[/b]  bit[noparse][[/noparse]&#173;32&#093;
    [b]PUB[/b] Start | i, x
      [b]repeat[/b] i [b]from[/b] 0 to 31
        bit[noparse][[/noparse]&#173;i&#093; := |< i
      x := $38
      i := 4
      [b]if[/b] (x & bit[noparse][[/noparse]&#173;i&#093;)
      [b]elseif[/b] (x & bit1)
  • RaymanRayman Posts: 16,460
    edited 2009-07-13 19:50
    I think a real easy way is use OUTA (assuming that cog isn't really being used for output...).
    You can just do:
    OUTA:=$38
    if OUTA[noparse][[/noparse]bit]
  • ericballericball Posts: 774
    Phil Pilgrim (PhiPi) said...
      [b]if[/b] (x & bit[noparse][[/noparse]&shy;i])
    I'd have to look at the SPIN bytecode, but I suspect "if (x & |<i)" will be faster than "if (x & bit[noparse][[/noparse]i])".· It also saves 32 LONGs of HUB RAM.
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: Forum
    OnePinTVText driver: ObEx Forum
