SX/B 2.00.28 Beta now supports nested Conditional Compile Directives — Parallax Forums
BeanBean Posts: 8,129
edited 2009-12-24 09:28 in General Discussion
I can't remember who asked for this feature...I think is was Peter ???
But I have implemented it, so I'd like you guys to give it a good test case.
Here is what I used to test it:
DEVICE SX28, OSC4MHZ
FREQ 4_000_000
temp1   VAR BYTE
 PROGRAM Start NOSTARTUP
  Start:
  ' This three defines TEST0, TEST1 and TEST2 determine which of the seven FOR statements are compiled
  '{$UNDEFINE TEST2}
  '{$DEFINE TEST1}
  '{$DEFINE TEST0}
  '{$IFNDEF TEST2}
    '{$IFNDEF TEST1}
      '{$IFNDEF TEST0}
        FOR temp1 = 0 TO 255
      '{$ELSE}
        FOR temp1 = 1 TO 255
      '{$ENDIF}
    '{$ELSE}
      '{$IFNDEF TEST0}
        FOR temp1 = 2 TO 255
      '{$ELSE}
        FOR temp1 = 3 TO 255
      '{$ENDIF}
    '{$ENDIF}
  '{$ELSE}
    '{$IFNDEF TEST1}
      '{$IFNDEF TEST0}
        FOR temp1 = 4 TO 255
      '{$ELSE}
        FOR temp1 = 5 TO 255
      '{$ENDIF}
    '{$ELSE}
      '{$IFNDEF TEST0}
        FOR temp1 = 6 TO 255
      '{$ELSE}
        FOR temp1 = 7 TO 255
      '{$ENDIF}
    '{$ENDIF}
  '{$ENDIF}
  NEXT
END
Bean
The needy are many, the deserving are few.
  • RS_JimRS_Jim Posts: 1,773
    edited 2009-07-13 12:55
    Thanks Bean,
    I will download and install later today! I recently was trying to do some stuff where nested compiler directives would have been very nice!
    RS_JIM
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-07-13 17:34
    Bean,
    Nested conditionals were already possible, but the condition was reset
    upon first $endif.
    I assume that is no longer the case and we have truly nested conditionals now.
    regards peter
  • BeanBean Posts: 8,129
    edited 2009-07-13 17:37
    Peter,
    Yes, they should be honest and truly nest-able now.
    The example program I show above will only generate a single FOR line depending on if TEST0, TEST1 and TEST2 are defined or undefined.
    Let me know if you get a chance to test it.
    Bean.
    edited 2009-07-14 11:49
    Just wondering if anyone has had a chance to test 2.00.28 yet ?
    Bean.
    Does that byte of memory hold "A", 65, $41 or %01000001 ?
    Yes it does...
    edited 2009-07-14 15:09
    Haven't tested all of the features, but it has worked perfectly on everything I done with it so far.
    I will be trying some of the nested conditional directives later today, will let you know how they work!
    RS_JIM
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-07-14 17:47
    Thanks Bean - nice improvement!
    I'll try it out over the next weeks.
    - Howard
    edited 2009-07-25 04:38
    @Bean,
    The following does not compile correctly:
    ' Conditional Compilation Symbols
    '{$DEFINE SERIAL}
    ' INTERRUPT
    '{$IFDEF SERIAL}
    INTERRUPT NOPRESERVE 230_400
    '{$ELSE}
    INTERRUPT NOPRESERVE 100_000
    '{$ENDIF}
    All of my other conditionals compile correctly including a nested one
    '{$IFDEF SERIAL}
    '{$IFDEF LCD_DSP}
    '{$ELSE }
    '{$ENDIF}
    IT Tries to use both interupt rates and the assemblier complains about overwriting the same program location. I can also tell from the __INTOPTION that it is picking up the second value (10,000) as it equats __INTOPTION to $80 not $88. If I don't use the conditional and just comment out the interupt option I don't want, it compiles/assembles correctly. I have conditionals burried in the interupt load file and that is working correctly.
    RS_JIM
    '{$ENDIF}
    edited 2009-07-25 15:01
    Jim,
    Could you post the entire program.
    I tried this and it seem to work properly.
    DEVICE SX28,OSCXT2
    FREQ 20_000_000
    '{$DEFINE SERIAL}
    ' INTERRUPT
    '{$IFDEF SERIAL}
    '{$ELSE}
    '{$ENDIF}
    RETURNINT
    PROGRAM Start
    Start:
    END
    Bean.
    Yes it does...
    edited 2009-07-26 13:28
    @Bean
    Thanks for checking.· Problem was with a redundant declaration of the program ID!
    RS_JIM
  • BrooksLBrooksL Posts: 17
    edited 2009-11-19 19:11
    I'm having·frustrating trouble with the conditional compile directives while porting our BS2px code to SX28AC with SX/B (need speed and interrupts).·
    I find it very confusing and odd that the syntax for these directives starts with the· '· comment delimiter.· Does that mean these lines can't be commented-out??· Using '' <-- that's two '· does not seem to work; the conditional compile is taken regardless.··· And, I must admit that I'm curious about the reason for implementing these this way.
    example:
    '{$DEFINE Bluetooth}······························ 'compile Bluetooth code if defined (true)
    ''{$DEFINE COMport}································ 'compile serial port I/O if defined (true)
    '{$DEFINE EnFilter}······························· 'enable digital filtering of sample data
    ''{$DEFINE DebugMode}······························ 'compile debug statements if defined (true)
    ''{$DEFINE DualAxis}·
    I could see changing DEFINE to unDEFINE, but it gets more difficult if I want to comment out the IFDEF...ELSE...ENDIF's
    Got·any helpful guidance?
    -- BrooksL
    edited 2009-11-19 19:25
    Bean asked "...if anyone has had a chance to test 2.00.28 yet ?"
    What does that version number refer to? SX/B compiler version?
    Is SX/B 1.51.03 no longer the latest?
    --BrooksL
  • JonnyMacJonnyMac Posts: 9,528
    edited 2009-11-19 23:39
    Brooks,
    We moved past 1.5x a long time ago -- but you have to install it manually (the IDE installer hasn't been updated with the 2.x files). You can find what you need in a sticky post at the top of the SX forum.
    You cannot "comment out" conditional directives -- you can modify the define directive to turn things on and off. I tend to do things like this:
    ' {$DEFINE DEBUGGING}
    ...and when I want it off I change it to:
    ' {$DEFINE DEBUGGING_OFF}
    edited 2009-11-20 00:26
    Thanks Jonny; where do I get the current SX/B compiler - AND documentation? I only saw 1.51 on the Parallax SX web page.
    I use conditional compile directives a lot for feature options. This ' comment delimter in the SX/B directive syntax is creating an annoyance for the porting of other code. ...and I can forsee it causing possible future difficulty.
    Today for example, I finally spotted '{$IF ... } instead of '{$IFDEF ... } and '{$IF ... } appears as a comment to the SX/B compiler so it fails to generate a syntax error!? That took hours to notice - as will any others that get in there!
    -- Brooks
    edited 2009-11-20 02:01
    It's hiding here at the top of the SX Forum --
    http://forums.parallax.com/showthread.php?p=780347
  • PJMontyPJMonty Posts: 983
    edited 2009-11-20 02:27
    The IDE hasn't been updated because S/B is still in Beta. When SX/B comes out of Beta, then the IDE will be updated.
    PeterM
    edited 2009-11-20 03:07
    JohnnMac suggested:
    The confusion comes in that with the ' comment delimiter, you can change it to just about anything:
    '{$DEFINE DEBUGGING_OFF} or
    '{$UNDEFINE DEBUGGING} or
    '{$NODEFINE DEBUGGING} or
    '{$STOPDEF DEBUGGING} or
    '{$DEF DEBUGGING} ....
    All but the first has the same effect and the compiler won't check or enforce a standard syntax with error messages - because they look like comments. :-/ More dangerous; what if you have a define (or any) directive like '{$DEFINE DEBUGGING} or {$DEFINE DEBUGGING} floating somewhere in a real 'comment statement - wil lthe compiler process it as a valid directive??
    ...Since SX/B 2.x is in beta... can this ' issue be "fixed" before release? - not just because it's bugging me right now (obviously, I'll have to work around it for the time being), but because there seems to be a lot of potential problems with it.
    -- BrooksL
  • ZootZoot Posts: 2,227
    edited 2009-11-20 04:54
    BrooksL said...
    No, they will not.
    '{$DEFINE XYZ}
    above means XYZ is defined (true)
    ''{$DEFINE XYZ}
    not defined
    ' { $DEFINE XYZ}
    not defined
    etc.
    Not sure what the issue is? Rather then even "undefining" I would just comment out the define, e.g.
    '{$DEFINE debugging}
    '{$IFDEF debugging}
      'lots of code  that will compile
    '{$ENDIF}
    ''{$DEFINE debugging}
    '{$IFDEF debugging}
      'lots of code  that will NOT compile
    '{$ENDIF}
    edited 2009-11-20 05:07
    I stand corrected; thanks Zoot; I will "comment out" future directives when needed.
    edited 2009-11-20 05:45
    Thanks, Zoot. my initial assesment was clouded by having '{IF ... } instead of '{IFDEF ... } and not having the compiler catch it as a syntax error - because it looks like a 'comment due to the ' - my tests of '{DEFINE ... } and ''{DEFINE ... } both appeared to have the effect of making the variable true.
    Thanks for listening. And, it sure would be nice if conditional compile directives were recognized as regular keyword syntax...
    edited 2009-12-23 23:49
    Newbie question: is there a way to use the virtual peripherals with SX/BASIC?
    I'm hoping the answer is yes and that there's some guidance somewhere, but it's not obvious because I couldn't find an affirm or decline nor any mention in the SX/B manual.
    -- BrooksL
    edited 2009-12-24 03:07
    @BrooksL: It's bad form to change the topic of a thread mid-stream. Start a new thread with an appropriate subject line. BTW... the answer is "Yes" -- get guidance by starting another thread.
    JonnyMac; oops, lost track of where I was posting; thought it was to the FAQ thread, but I'll start a new one.
    -- BrooksL
