FullDuplexSerial with 7/8 bits n/o/e-parity? — Parallax Forums
Nick MuellerNick Mueller Posts: 815
edited 2009-07-15 15:49 in Propeller 1
Hi!
Before I do that by myself, is there a variant of the FullDuplexSerial that can be configured to do
* 7 or 8 Bits?
* Odd, even or no parity?
* as an extra bonus selectable number of stop-bits?
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
  • KyeKye Posts: 2,200
    edited 2009-07-13 13:57
    Mine will do that fo you.
    It works for only 8 bits. But of course you can always make the last bit high as to make it only 7 bits that are transfered.
    Nyamekye,
    Post Edited (Kye) : 7/13/2009 4:35:18 PM GMT
    edited 2009-07-13 14:32
    It's very rare to find true 7 bit serial. Most of the time it's really 8 bits of data where the 8th bit is the parity bit (even / odd / always zero / always one).
    There's no need to configure the number of stop bits for receiving, only for transmitting when it's required. If you're using Simple_Serial which is not buffered, you can just add some delay between transmitted characters (one bit-time for each extra stop bit).
  • Nick MuellerNick Mueller Posts: 815
    edited 2009-07-13 14:43
    Am I right (had just a short look at it), that it supports parity just in 7 bit mode?
    Nick
    YADRO
    edited 2009-07-13 16:31
    Yup.
    Nyamekye,
    edited 2009-07-13 17:04
    That's right.
    But my requirement for sending data (to fullfill the standard) is 7 and 8 bits, with any parity and one stop bit.
    OK, I'll dive into the original assembler, should not be too complicated.
    Nick
    YADRO
    edited 2009-07-13 17:46
    Nick,
    There is no "standard" for this. True 7-bit serial is historical only. You will not find modern equipment capable of sending or receiving it. Modern equipment is all 8-bit data as I mentioned, with the 8th bit configurable to always hold a zero bit, a one bit, the even parity of the other 7 bits, or the odd parity of the other 7 bits. You can use FullDuplexSerial for this, unchanged, with all of the work on the 8th bit done by the caller. If you're doing it in Spin, you'd just have:
    case mode
       always_one:
          data |= $80
       always_zero:
          data &= $7F
       even_parity:
          data := (data & $7F) | (((data << 1) ^ (data << 2) ^ (data << 3) ^ (data << 4) ^ (data << 5) ^ (data << 6) ^ (data << 7)) & $80) ^ $80
       odd_parity:
          data := (data & $7F) | ((data << 1) ^ (data << 2) ^ (data << 3) ^ (data << 4) ^ (data << 5) ^ (data << 6) ^ (data << 7)) & $80
    ser.tx(data)
    edited 2009-07-13 21:32
    The standard is the standard of the protocol (ModBus) that requires these settings.
    7 bits for ASCII-transmission (Hex, two chars / byte), 8 bits for binary (called RTU) transmission.
    All that is no problem with 7 bits (o/e/n), but with 8 bits, I'll have to modify the ASM-code. The standard *requires* even parity for 8 bits.
    And when I'm doing that, it is more efficient to implement all requirements (7/8 o/e/n) at the ASM-level. Much faster (compared to counting/shifting/masking bits in a high-level language) and more size-efficient.
    I'm currently developing with the ASCII-transmission, because it is easier to read for me while debugging and testing, but I want to switch over to binary (keeping the ASCII-part) to speed things up. More than 50% (don't know the exact number right now) of the time (receiving a command, decoding and executing it and then sending a response) is spend with communication.
    Nick
    YADRO
    edited 2009-07-13 23:19
    I hope my code helped.
    Also you could be lazy and do it the higher level way. if speeds not a problem. =)
    Nyamekye,
    edited 2009-07-13 23:35
    Nick, I have written MODBUS drivers for the Prop but to tell the truth I didn't bother with 7-bit ASCII as although it may be a option for MODBUS I haven't come across it's actual use. I think I did do a serial coms driver with 7-bit and parity once but I will have to dig through my "junk box" and dress it up if you really do need it. Using 8-bit mode for receiving 7-bit data is fine as long as 2 stop bits are used because otherwise you may receive two 7-bit characters with only one stop bit between. What the Prop will see is a framing error as the start bit of the next character makes it look like that there is no stop bit for the last character.
    *Peter*
    edited 2009-07-13 23:38
    I don't see how I could set the 9th bit (the parity bit of a 8 bit transmission) outside of PASM. But I might be missing something.
    Nick
    YADRO
    edited 2009-07-14 02:31
    9 Bits?
    ... Yeah, guess you have to.
    Nyamekye,
  • caskazcaskaz Posts: 957
    edited 2009-07-15 15:35
    Hi.
    I also have trouble about FullDuplexSerial.Plus
    I put sinple-test-program on Propeller-Demo-Board.
    (sending "0", LED-P16 is ON)
    I connect Linux and Propeller-Demo-Board. But cannot communicate.
    I set 7bit no Parity 1-Stopbit to /dev/ttyUSB0 on Linux.
    Linux recognize device(Serial-To USB).
    Command from Linux
    #echo -n 0 > /dev/ttyUSB0
    What wrong?
    Please.
    caskaz,
    It is impolite to "hijack" another thread. Unless your question is directly related to the subject, please start your own thread.
    Linux probably supports actual 7-bit no-parity serial (with a start bit, 7 data bits, and a stop bit) which FullDuplexSerial doesn't support.
    Try 8-bit no-parity on Linux.
    You may have an error in your program so you must include that (as an attachment to a message, use the Post Reply button).
