PING))) Problems
The rawdata coming from the PING has a value of no more that 250 with a home made servo extension cable attached. When I plug the PING directly into the bread board it give me the correct readings up to 5000. The question is why would an extension cable give me such a variance? I tested the resistance on the cable and it measures .2 ohms, is this enough to cause a problem? I suppose there is more resistance after it runs through the breadboard and jumpers also. I don't know
Parallax Engineering
