POwer input for Super Carrier Board
From the Web page here
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/carrier/List/0/SortField/4/ProductID/122/Default.aspx
KeySpecifications:
Power Requirements: 6 to 30 VDC (6 to 15 VDC recommended)
Communication: Serial
Dimensions: 4.00 x 3.00 x 0.65 in (102 x 76.2 x 16.5 mm)
Operating Temperature: -40 to +185 °F (-40 to +85 °C)
I assume I can just plug in a 12v power source from the car battery (knowing it may get up to 14.4v when running)
I also assume that I should solder the wires to the board next to the 9v battery plug on the Vss and Vin connections ?
John B
KeySpecifications:
John B
Within the capability of the voltage regulator ( it can get very warm with high input voltage and modest current consumption) any input voltage from 8 to 30 VDC will work fine. I changed the regulator on mine to a switchmode type ( PT5101N ) to minimize the heating concerns.
Cheers,
Tom Sisk
http://www.siskconsult.com
