RFID Reader Code Help
Hi everyone,
Not sure if this is the correct forum for this question or not but I am working on a car detector project. I am using Visual Basic 2008 to code the RFID Reader and so far it reads and displays the tag ID. I am trying to get it so that if this tag ID equals the tag ID then it is car #1. For example
If tag = "190037945C" then
textbox2.text = "car #1"
end if
When I try this nothing gets displayed in textbox2, so I am not sure if I am going about this the right way or not.
end if
Jeff T.
Public Sub RFIDReader()
data = data + RFID.ReadExisting()
If Len(data) = 12 Then
TextBox1.Text = Microsoft.VisualBasic.Mid(data, 2, 10)
RFID.DtrEnable = False
EnableDTR.Enabled = False
DisableDTR.Checked = True
If TextBox1.Text = "190037945C" Then
TextBox2.Text = "Car #1"
ElseIf TextBox1.Text = "19003791E0" Then
TextBox2.Text = "Car #2"
End If
I think it was before textbox1.text = textbox1.text + VisualBasic.Mid(data, 2, 11)
The extra textbox1.text kept putting in the tag id in over and over so I think that is why it couldn't identify the tag.
Could you please explain to me, how to get the Tag-id onto your program. How do you read the Tag-id so that you use it in your program
Thanks & Regards,
Tan
#2) It takes very little Basic stamp code to read the RFID card
#3) The read in is then "echoed" by the basic stamp through and to the rs232 port of the Basic stamp through a debug statement.
#4) VB then read that info into the VB 5 program.
all code can be provided for the Basic Stamp and VB 5
tmart2007@GMail.com - ted
what is interesting is that you can send code with the debug statement that tells it whether it is door A or B
for instance:
Enable pin 0
RX pin 1
RT pin 2
sData Var Byte
T9600 Con 396
# SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
#CASE BS2SX, BS2P
T2400 CON 1021
#CASE BS2PX
T9600 CON 396
#ENDSELECT
buf Var Byte(10) 'reading ten digits
tagNum var Nib
idx Var Byte
Reset:
HIGH Enable
Main:
LOW Enable
Serin RX T2400, [WAIT($0A), STR buf\10]
HIGH Enable
Display _Tag:
DEBUG "Door A", CR
For idx=0 to 9
DEBUG buf(idx)
Next
DEBUG CR
PAUSE 500
GOTO Main
this code sends the tag info read to the buffer and will put it on the screen of the Basic Stamp program
Just need to parse it in VB and take out what you want and the 10 digits or part of the 10 digits
I only use the last three digits of the RFID tag with about 700 tags
I then use a VB routine in the visual basic program to set off a relay for door A or B. The relay is set off through the parallel port to an 8 relay board controlled by the parallel port. A or B is parsed out to tell me which door to set off the relay for.
thanks
ted
