Problem writing to SD card
Hugh
Folks,
I'm trying to write to an SD card using the excellent fsrw object, but am having some problems.
What I get is a file with 500 "œ" characters, each with 25 spaces before them. I'm obviously making a fundamental mistake here, but can't see the wood for the trees.
Any suggestions / pointers would be gratefully received - I have been through the 'insert SD card - turn on Prop - upload code - wait for it to mount / write - turn off Prop - remove SD card - insert SD card in PC - open file - close file - alt-tab to Prop tool - change code' loop so many times now!
Many thanks,
Hugh
P.S. Its an OBD code reader for my Saab that shows live data on an LCD display - I want to log one or two parameters to SD every couple of seconds.
Hugh - the thinking woman's Geoffrey Pyke.
OBJ sdfat : "fsrw" lcd : "LCD" VAR Byte mode, index, fast, tRef, recData[noparse][[/noparse]100] , AnsaA [noparse][[/noparse]25], tbuf[noparse][[/noparse]20], r, sta long txDisp, units , AnsaB, Ansa, stack1[noparse][[/noparse]20], stack2[noparse][[/noparse]20], stack3[noparse][[/noparse]20] pub main waitcnt(80_000_000 + cnt) sdfat.mount(00) AnsaA:=string("Test") ' What I am trying to write to the SD card lcd.cls if r ==0 lcd.str(string("Mounted.")) waitcnt(240_000_000 + cnt) sdfat.opendir repeat while 0 == sdfat.nextfile(@tbuf) sta := cnt else lcd.str(string("Failed!")) sdfat.popen(string("Data1.csv"), "a") repeat 500 ct :=0 ' repeat 20 ' sdfat.pputc(AnsaA[noparse][[/noparse]ct++]) This didn't work sdfat.pwrite(@AnsaA,25) sdfat.pputc(13) 'Carriage Return sdfat.pclose
Many thanks,
Hugh
2. The string is only 4 bytes long, so don't tell pwrite to write 25 bytes.
pwrite(AnsaA, 4)
PS:
Ah ... I see .. you have a big missunderstanding in the string-instruction. string won't copy the string into your array. string stores the string you pass as a parameter somewhere in a dat-section and returns a pointer to that place.
By the way .. you could also write:
AnsaA:=string( "Test", 13)
Then you don't need the putc.
Post Edited (MagIO2) : 7/11/2009 4:13:23 PM GMT
